Home > Tdi > 200 TDI injection pump
mini Anaconda
Its possible that my injection pump is leaking between the head unit and main body, its my understanding that you can carefully release the head unit a small amount to remove and replace the large o-ring/seal. Has anyone on here carried out the repair with success?
I have watched a video on youtube which involves removing the top of the pump to make sure a shim doesn't fall off a cam inside the pump, is it possible to carry out the repair without removing the top of the pump?
Many thanks.
Post #573790 27th Oct 2016 2:47pm
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
Mine also leaks.
Replacement pumps are stupid expensive , I was advised to send mine off as a px for a refurbished I e.
Still not done it Rolling Eyes
I watch this one closely Thumbs Up
G My confidence has been writing cheques that my abilities can't cash for years.
Post #575736 6th Nov 2016 12:54am
Retroanaconda
When mine developed a leak I bought a second hand one and sent it off for refurbishment at Diesel Bob. Then swapped it for mine once it arrived, not that bad a job.
Still got my original here if anyone needs one to do the same.
Post #575776 6th Nov 2016 9:50am
mini Anaconda
Going to give it a try in a couple of weeks, will update with the outcome.
Post #576964 10th Nov 2016 9:03pm
mini Anaconda
I am pleased to say we carried out the repair and it seems to have been a success. In the end we decided to remove the pump from the Land Rover and replaced the seal with the pump sat in a vice, this made it a lot easier. Haven't done many miles yet but so far so good.
Post #583573 8th Dec 2016 8:42pm
