![]() | Home > Td5 > Td5 Re-map |
NickEJ Member Since: 24 Nov 2012 Location: Ljubljana Posts: 152 ![]() ![]() ![]() |
Hi guys,
After many years of contemplation I finally took the plunge yesterday and had my 2004 Td5 remapped by Tdi Tuning. I was a little concerned as I was informed after my arrival that it is not a "plug and play" on the Td5 for their device but requires splicing and soldering onto the existing loom. That being said, the results are immediately apparent with a noticeable increase in power and smoother delivery all through the rev range. The device is even variable with 7 different settings from max MPG saving to max power. Well worth the money so far, especially as I'm about to embarque on a long journey and I will now be able to cruise comfortably at 65mph. Cheers Nick |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 ![]() ![]() |
Have you done the transfer box upgrade/modification?
No but it was a toss up between that and/or the re-map. Be interested to know what difference the transfer box change would have made but the re-map has achieved what I wanted.
