Home > Maintenance & Modifications > Aluminium for Holes
tyrannosauROSS
United Kingdom 2006 Defender 110 Td5 CSW Chawton White
Aluminium for Holes
Good evening.
I have a 110 SW and have removed the rear seats on the wheel arches. Where the seats were bolted through I now have holes.
My plan is to bond some aluminium "patches/pannels' to the underside of the wheel arch as to maintain a flat surface on the inside.
To bond the patches in I intend to use CT1.
Does anyone have any recommendation on what type of Aluminium to use as to reduce the corrosion between the two types. I know I am incredibly unlikely to find an exact match for the tub.
Also, the underside the wheel arches and chassis have been coated using a Waxol type product. Any tips on how to clean this off as to get a good bond between the two metals?
Thanks
Ross
Post #575055 2nd Nov 2016 9:51pm
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
I feel quite inadequate, I just used duct tape on the inside.....
Post #575056 2nd Nov 2016 9:56pm
Buy an old tub perhaps ?
Post #575092 3rd Nov 2016 6:53am
Cupboard
I just bought some aluminium sheet from eBay and used some two part epoxy.
Scraped off crud from underneath, cleaned with WD40 then degreaser, put patch on, left for 24 hours.
My patches all have a 4mm hole in the middle so I could clamp them tight whilst the epoxy was going off.
Given that there is going to be very minimal metal-metal contact on account of the stuff you're using to stick them, I wouldn't worry too much about getting the grade exactly right.
Post #575100 3rd Nov 2016 8:28am
Leviathan
Is it this panel?
I replaced it with a new one because of holes in the aluminium. Not difficult but time consuming.
I glued a thin shim of rubber sheet between the steel crossmember and the new panel.
Post #575161 3rd Nov 2016 2:55pm
excossack
How do you remove the white section of metal? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #575189 3rd Nov 2016 4:13pm
Leviathan
Lift the floor, drill out the rivets, use a grinder to cut it out leaving about 20mm lip.
Then use a scrapper to separate the sealed joints.
Most awkward part is easing the folded corner uprights out to fit the new panel.
Post #575345 3rd Nov 2016 11:16pm
