Home > Maintenance & Modifications > On-Board Air |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
Get a Viar off Matt Savage
7th Feb 2011 7:25pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Ive got an ARB heavy duty one under my drivers seat and store the airline under there, it's a little tight but does fit. Obviously drives the difflock as well. Original Member Pie n Pea Club.
110 HCPU Tipper |
7th Feb 2011 7:26pm |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 |
Not got a diff-lock just yet, but may end up with one in the future. Do you guys have air tank /reservoir too? what's the benefit - presume it's just a bit quicker to pump tyres up etc and you may be able to run air tools off it if the tanks big enough...
7th Feb 2011 7:31pm |
I haven't got an air tank, the compressor is quick enough for pumping up tyres, though I don't think you could use it to pop a bead back on. Airtools... just go electric nowadays. Original Member Pie n Pea Club.
110 HCPU Tipper |
7th Feb 2011 7:34pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
On red 110 300 TDi we have an engine mounted compressor, a 9 litre air tank under floor. The pressure gauge/switch is mounted just by O/S middle door with a long coil airline n the cargo barrier.
The tank will hold 150 psi/10 bar. From stopping, inflating all tyres from 20psi to 38 psi takes about 8 minutes to moving off. Just be careful using high pressure/high volume on diff lockers as they can create problems Brendan |
7th Feb 2011 8:20pm |
