![]() | Home > Td5 > Bloody TD5's! |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1366 ![]() ![]() |
![]() Last edited by AJC on 10th Nov 2016 3:59pm. Edited 1 time in total |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
Possibly the oil pump drive sprocket bolt? Apparently it wasnt just the early engines that were effected
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2957 ![]() ![]() |
I had this problem a while ago sticky pressure relief had new oil pump👍
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Before you get too stuck in it is worth checking the wiring to the pressure sender or even better plugging a mechanical gauge in. Steve 02' 110 TD5 Double Cab Rebuild Thread
Going to get a mechanical guage plugged in tomorrow and see what it says, quick search on the net suggests it could be oil pump bolt or oil pump.
