![]() | Home > Td5 > Alarming |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Pull ultrasonic sensor from head lining (it just unclips). Unplug the unit and it will no longer trigger the alarm. No setting changes required to disable it. Just make sure you dont loose the woring behind the headlining in case you want to reconnect it.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2178 ![]() ![]() ![]() |
The door contacts are prone to deterioration, so I'd clean or replace them as a matter of course. They are only cheap.
As above, just unplug the volumetric sensor and see how it goes. Hopefully you have other layers that will but your mind at rest whilst you trace the fault. |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
I did the same mod on mine, when you lock the drivers door with your key it locks all the doors but the immobilizer and volumetric system is not activated. I use this when I leave my dog in the car for a few minutes. Also we don't have the rampant Defender theft issue over here. Just an idea for you. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
