Home > Maintenance & Modifications > Cleaning Crud out above rear crossmember |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Other than getting in there with a screwdriver and a pressure washer whilst getting very wet I don't think that there are many other options. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
30th Oct 2016 4:18pm |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 488 |
I have cut down a couple of old rubber floor mats and attached them at the top of there going all the way down to the bottom of the cross member, reduces the crud significantly. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
30th Oct 2016 5:19pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
I've used screwdriver and compressor
30th Oct 2016 6:59pm |
Screwdriver compressor and paint brush for me.
30th Oct 2016 8:13pm |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
On our 110 there is a plastic trim that can be removed from under the gaurd.
This gives access to the fog light plinth nuts and the wireing. I've fitted a locker in the LH void and there are water tanks that fitt there too. By doing this access is not possible except by removing the lights. To allow this I converted the reverse light plinth from rear nuts to Nutserts. I've also converted my fog lamp to a reverse but not sure this would meet your MOD requirements. Cheers, Kyle. |
30th Oct 2016 9:13pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
Pressure washer and stand as far to one side as you can!
30th Oct 2016 10:40pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2080 |
As above plus a small bottle brush (not the plant!)
31st Oct 2016 8:39am |
