Home > Td5 > Main wiring loom
Collydog Blue
United Kingdom 1999 Defender 90 Td5 CSW Epsom Green
Main wiring loom
I put a post on here a month or so ago asking for advice about having no headlights and I got a fantastic response and loads of help, but having been through everything, fuses,switches, earths etc, and after weeks of no joy it transpires that it's the plug on the main wiring loom has corroded and burnt.
Having tried to source a plug to replace it is impossible, and every parts dealer and scrappy I've spoke to has stated that you cannot get a plug you have to replace the full loom, which at a new part which only Land Rover supply is £2480.
So it's a big ask to see if anyone has an old wiring loom I could salvage the plug from, or any knowledge of any dealers that supply loom parts separately. Thanks Sad
Post #574342 30th Oct 2016 12:35pm
dorsetsmith
The part is a (header) conman to land rover wire looms as you no
Post #574343 30th Oct 2016 12:42pm
Collydog Blue
Thanks Dorset , I think they should re-name them to rocking horse poo.
Post #574344 30th Oct 2016 12:47pm
Could you take a photo of it looking at the plug?
Post #574345 30th Oct 2016 12:54pm
dorsetsmith
also have LR parts numbers BUT its of no use as part all obsolete have repaired loom my self will post the parts i used instead for headers
Post #574348 30th Oct 2016 1:12pm
Collydog Blue
Thanks much appreciated.
These are the only pics I can get today, as my landy is locked in my mates yard until Wednesday.
Post #574349 30th Oct 2016 1:24pm
dorsetsmith
Post #574350 30th Oct 2016 1:29pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I bought a few similar connectors from PaulMc who posts on here. He seems to know lots about availability of loads of different Land Rover connectors. Perhaps worth dropping him a PM.
Post #574352 30th Oct 2016 1:32pm
Collydog Blue
[quote="dorsetsmith"]http://www.ebay.co.uk/itm/Wago-222-Electrical-Connectors-Wire-Block-Clamp-Terminal-Cable-12V-240V-Reusable-/321977178926?var=&hash=item4af755db2e:m:mRleF4fo2Wg9Ltacp9XhpA
Thanks, will have a look.
Post #574355 30th Oct 2016 2:02pm
Collydog Blue
Thanks will do 😄
Post #574356 30th Oct 2016 2:03pm
dorsetsmith
each header is connected diffidently interiorly and 7 blue ones in the main td5 wire loom not inter changeable
C0288 header is only blue header in head lamp and side lamp cct
Post #574359 30th Oct 2016 2:13pm
Collydog Blue
Thanks Dorset, if I ever get chance I'll buy you a few beers, 🍻😁
Post #574360 30th Oct 2016 2:22pm
Mo Murphy
PaulMc has proper headers with the terminals to suit for about a tenner IIRC. PM him on here.
50 Shades of Pennine Grey
Post #574430 30th Oct 2016 7:23pm
Mo Murphy
Search for landrover-connectors on ebay. He hasn't got any on at the mo but a message via eBay should get you sorted out.
HTH
Post #574433 30th Oct 2016 7:33pm
Collydog Blue
Thanks Mo, I have Pm'd him, bug will try on eBay as well, thanks again. Hopefully I'll get it sorted 🙏
Post #574466 30th Oct 2016 9:44pm
