Home > Td5 > Bad MAF
mustafasoleiman
United Kingdom 2003 Defender 90 Td5 XS CSW Indus Silver
Bad MAF
My 2003 Defender 90 was struggling when accelerating, and after reading many an advice here, I decided to try and unplug the MAF power supply.
The acceleration was immediately improved, the engine smoother.
Now I am keeping an eye on the fuel consumption to see if that improves as well.
In the meantime I'm wondering what are the possible issues of not having a MAF at all, as opposed to replacing it.
Any ideas on the pros and cons?
It'll take me about a week to find out about the fuel, after that I will decide.
Btw there are no other mods to the engine.
Alex
Post #574116 29th Oct 2016 8:17am
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
You will find that it's a bit gutless without a MAF at low revs. For example mine would reverse off our steep drive on tickover with a working MAF, but wouldn't with either a faulty MAF or with it unplugged. In fact that was always the first indication that the MAF was starting to fail.
The general advice is do not waste money on a cheap MAF - get a proper OEM version from a reputable supplier. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #574118 29th Oct 2016 8:26am
Tiger
£70 to get a new OE, bit of a no brainer
Post #574126 29th Oct 2016 9:21am
mustafasoleiman
It's not a financial issue TIGER, it's curiosity to know what are the advantages and disadvantages on not having a MAF.
I will get a new good quality one as soon as I am done with my silly curiosity...
NOSNIBOD has given one disadvantage: gutless at low rev... I will look for that, thank you.
Post #574139 29th Oct 2016 10:31am
roel
I found that there is a bigger difference between a bad MAF and No MAF then there is between a good MAF and no MAF. Twisted Evil
And somewhere in between you have a working MAF that doesn't give the right values. Roel
2003 90 Td5 (2009-now)
Post #574278 29th Oct 2016 9:50pm
