Home > Maintenance & Modifications > Suspension confusion - Bowler versus Alive?
Robo1
United Kingdom 2012 Defender 90 Puma 2.2 X-Tech LE Orkney Grey
Apologies for bringing up again the subject of suspension, but having trawled the forums I am still confused about what is the best set for my 90 XTECH. The majority of my driving is on the road and the Bowler suspension package looks like a good but expensive solution to improve handling. Is the set up worth the extra cost in comparison to buying the shocks etc and fitting yourself?
I was also thinking about the Alive lowering springs but having read the post on propshaft alignment might give them a miss. Any advice/experience with either the Bowler or Alive set-up would be great thanks.
Post #574004 28th Oct 2016 4:17pm
I have the Alive springs on both 90's after driving a mates 90 with them fitted. No more harshness Cool
Post #574021 28th Oct 2016 5:35pm
Robo1
Thanks for the feedback Smile Will see if I can find a Defender with that set up for a try.
Post #574121 29th Oct 2016 8:56am
Morepower
New Zealand
Having tried both on the 110 USW, They are totally different... The Alive set-up is far softer during normal road driving, The truck also rolls a little less (As it's lower).... However, If you load the rear up as intended it can be quite low at the rear...
The Bowler set-up (now fitted) is less forgiving, But works better carrying loads... I also found the Bowler rebound dampening better... But all this is subjective and you need to try both...
I also have a 90 with the full Bowler kit and its very very good...Although not for pottering around...
Hope this helps
Regards
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #574136 29th Oct 2016 9:55am
Robo1
Thanks Tim for the insight, really helpful!
I would ideally like to go for the full Bowler fast road upgrade to my 90, but think it might be a difficult one to swing past my better half. I have had the Xtech for 12 months and so just upgraded the power with a a remap courtesy of BAS, which is brilliant!
Appreciate its not a sports car, but it would be nice to improve the on-road handling - reduce body roll etc. It sounds like the Bowler option is the one to go for in terms of handling.
Cheers,
Rob
Post #574146 29th Oct 2016 11:58am
