Home > V8 > Vac advance
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
Vac advance
Hello fellow V8 owners,
I've noticed I have only one rubber hose coming from my distributor, going to the carburettor, there is a connector on the other side of the vac advance with no hose. Is this connector meant to be left like this, if not where should I connect it too? 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #572076 19th Oct 2016 4:33pm
Iggle piggle
United Kingdom 1989 Defender 90 V8 Petrol ST Alpine White
Yes only the one vac pipe needed, the other port is a vent I think
Post #572106 19th Oct 2016 7:07pm
charcoal
Is that the one that comes out the front of the vac advance or the rear next to the distributor connection? 1999 Land Rover Defender 110 td5 station wagon
Post #572119 19th Oct 2016 7:40pm
Iggle piggle
From memory the vac pipe goes on the one pointing away from the distributor,
But I'll check tomorrow Thumbs Up
Post #572141 19th Oct 2016 8:19pm
charcoal
Great, thanks Iggle Piggle Thumbs Up 1999 Land Rover Defender 110 td5 station wagon
Post #572169 19th Oct 2016 9:01pm
Iggle piggle
Sorry Charcoal, I forgot all about this,
as I thought it is the port pointing away from the distributor & there is nothing on the other one
Post #573254 25th Oct 2016 8:06am
charcoal
No problem, same setup as mine then. mine has a plastic box thing half way down the vacuum line that I believe is a vacuum delay, yours doesn't appear to have it though. Will try taking it out and see if anything improves. 1999 Land Rover Defender 110 td5 station wagon
Post #573289 25th Oct 2016 12:12pm
Iggle piggle
Yes that little valve is to delay the vacuum advance when the throttle is snapped open,
I was told & also read in the link below they can give more trouble than they are worth so when I replaced the vac pipe I didnt fit it & put it somewhere safe, needless to say if haven't seen it since!
http://www.gomog.com/allmorgan/regulator.html
is your not running right after the rolling road session?
Post #573300 25th Oct 2016 1:23pm
charcoal
Interesting, will get rid of the valve also. The carburettors have been tuned well on the rolling road, the misfires and high idle turned out to be caused by something in the ignition system. I've replaced the distributor first as the old one is very warn and the rotor arm has a good few centimetres of play. then I had to swap them back because I had a loose piece of swarf in the new distributor which killed the ignition module. Finally got a new module and getting round to refitting the new distributor again. 1999 Land Rover Defender 110 td5 station wagon
Post #573303 25th Oct 2016 1:49pm
charcoal
Putting the new dizzy in seems to cure all problems except the misfires around 80mph. Not a problem though as I rarely need to go that speed. 1999 Land Rover Defender 110 td5 station wagon
Post #573900 28th Oct 2016 1:12am
