Home > V8 > V8 parts?
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
V8 parts?
I am curently rebuilding a 1988 SD1 rover V8 to drop in my 88" series 3 project.
Firstly has anyone any recomendations for part suppliers?
I'm aware that Craddocks do a fair bit, but would still like to find other outlets.
Who is your "go to place" ?
I am planning on keeping the engine fairly standard and within factory spec HP output, due to the nature of what it's going to power!
Any ideas would be appreciated,
Cheers 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #573478 26th Oct 2016 9:29am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I used Lrdirect for my gasket sets, will be ordering more bits from them once the build starts. What parts are you after? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #573483 26th Oct 2016 10:06am
ian series 1
Cheers, it's Mainly gaskets and pipe work, especially the rubber pipes for the flame traps, and carbs.
Most of it seems to be missing, and I would like to replace it with the correct parts, rather than bending straight bits of pipe to fit.
I've had It running on the floor, and it sounds quite sweet, i think it's been sat for many years, it needs anything made of rubber replaced! I want to strip it, hot wash the block and heads to get the gunge out of it, and go from there... 80" 80" 86" 88" 90"
Post #573489 26th Oct 2016 11:09am
Mash
Sounds like mine, static for a few years, stale fuel but still started and ran sweet! I'm going down the light upgrade route from a company on eBay, new cam/carb etc. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #573613 26th Oct 2016 6:45pm
ian series 1
I'm hoping to get away with spending too much on it!
Im going to start it with an oil pressure gauge fitted at the weekend, so hopefully that will give me a rough idea of it's internal condition, I know V8s can suffer quite badly with presure problems, due to lack of oil changes.
I did think about a high lift camshaft, but like I say I would rather keep it standard.
Not sure how much difference they make to power gains?
It's the higher compression SD1 lump, so should be fine as it is for a series box.
I could do with finding the standard air box set up, but original parts seem hard to get hold of now?
I've been looking on eBay, and it's supprising how much they fetch Shocked 80" 80" 86" 88" 90"
Post #573618 26th Oct 2016 7:01pm
I have a v8, with new hi torque cam, followers, front timing chain and gears and big end bearings all brand new. Complete and been around the block ( literally about 400 yds )
It's a 3.5 efi and basically complete. Head gaskets gone. £100 as is. I need it gone. In case that may be any use to you?
Post #573620 26th Oct 2016 7:04pm
ian series 1
I might take you up on that one!
I will have a weekend on mine, to see if it's all ok?
If not, I may be giving you a shout.
With the old EFI, I take it you can use any 3.5 V8 ECU?
This was my first choice of engine, and still maybe an option.... Whistle 80" 80" 86" 88" 90"
Post #573624 26th Oct 2016 7:14pm
Well it's in the way, and although I have receipts for hundreds for what I've done to it, I was going to make a coffee table.
But I'm having a massive cleanse in the garage and getting rid of loads of stuff, especially anything that will make me more work.
No rush, no pressure, it's there if ya want it. Includes starter, alternator, MAF and a few other bits n bobs.
I can't answer your ECU question though sorry, not a clue! In fact I gave my ECU to a friend with a Morgan, as a spare to carry on his euro trips.
Post #573627 26th Oct 2016 7:22pm
No need to hope. It's inevitable with a Land Rover Laughing Darren
Post #573632 26th Oct 2016 7:30pm
ian series 1
Thanks very much for your offer Greeni.
I will let you know by Sunday Thumbs Up 80" 80" 86" 88" 90"
Post #573633 26th Oct 2016 7:31pm
ian series 1
I've spent WAY TOO MUCH on land rovers in the past 2 years, so it would be nice to have a straight forward project!
Although I've just blown the budget on the series 3 with a new galv chassis... Laughing 80" 80" 86" 88" 90"
Post #573634 26th Oct 2016 7:34pm
noworries4x4
The best people for all things V8 are Real Steel Uxbridge. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #573637 26th Oct 2016 7:46pm
ian series 1
Thanks for that, I will look them up Wink 80" 80" 86" 88" 90"
Post #573641 26th Oct 2016 7:55pm
