Home > Maintenance & Modifications > Changing Ignition Switch
My ignition switch is playing up - it doesn't always spring return from the starter position, so the electrics die before the engine is running. I suppose that after 158k miles, it's just worn out.
Anyway, I have a new switch to fit and I've bought replacement shear bolts but, before I start taking things apart, am I missing anything other than brute force to remove the existing shear bolts?
Thanks for looking. Darren
Post #573512 26th Oct 2016 12:13pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I didn't even attempt the brute force method when I changed mine, as I decided there just wasn't enough room and the risk of collateral damage would be great.
I ended up using my Bosch PMF180 multitool with a modified metal cutting blade on, and cut down through the shear bolts between where the two parts of the alloy casting come togther.
It was pretty fiddly, but it was the only way I could see of doing it without using some sort of physical violence.
Pete
Post #573524 26th Oct 2016 12:49pm
gilarion
I used a small pointed punch and hammer on the shear bolts heads, fiddly at first but once you get the bolts turning it becomes easier and eventually they just spin out. Using a grinder or brute force risks damaging the steering shaft. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #573544 26th Oct 2016 1:34pm
Thanks guys. Some useful ideas to try Thumbs Up Darren
Post #573553 26th Oct 2016 2:27pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Exactly how I did mine. Just kept hitting the punch off centre of the bolt and was persistent. After a little while, the bolt began to spin out. Seemed to work fine, slow and steady wins the race. it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #573582 26th Oct 2016 5:11pm
That is the "industry standard" method.
Post #573585 26th Oct 2016 5:17pm
Drill and extractor ?
Post #573644 26th Oct 2016 8:04pm
Very, very difficult to centre the drill.
Post #573687 26th Oct 2016 9:38pm
