Home > Td5 > Relay Identification in Defender TD5 Battery Box |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 |
I believe all three are for the towing electrics.
The yellow Voltage Sensitive Relay energises when the alternator is working and is used as a trigger to the other two relays that feed the towing socket (either a 12S or a 13 pin). One relay is for the fridge feed and the other for the caravan battery charge feed. Dave Green Goddess - 1998 Defender 110 300tdi |
25th Oct 2016 9:10pm |
hunter_pa Member Since: 15 Aug 2016 Location: Northern Ireland Posts: 18 |
Cheers nosnibod, that makes sense now. You saved me the time having to trace the wires!
Its a bit of a messy install, the wires from those relays seem to go everywhere, which leads me to my next question. Is there any harm permanently disconnecting the battery? I wouldnt mind taking the battery out to see what space i'm working with, and to tidy the wires up. But i'm not sure if this will cause issues with ECU/immobiliser? |
25th Oct 2016 10:43pm |
