Home > In Car Electronics > Strange Headlights and Speaker?
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Ciao,
Last week one of my headlight, low beam bulbs blew, about a week later the other side went. High beam remains serviceable... the vehicle is a 18 months old Puma and the bulbs were Philips night breakers.
I will replace the headlight bulbs today and check voltage but I find it strange how they went within a week of each other.
I have also noticed that for about 30 seconds after I key on, (but not start the engine) I get a quiet buzz from the front left speaker.
Any ideas?
Yan
Post #573249 25th Oct 2016 8:38am
MartinK
Yan
It's not unusual for bulbs to blow at around the same time.
Happened to me recently (twice). One bulb blew...replaced...and within 2 weeks the other one blew.
It's like they have a pre-programmed "life" Smile
Can't answer about the speaker noise tho - you sure it's the speaker and not something else (a relay or pump) behind? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #573251 25th Oct 2016 8:51am
Not so strange perhaps. Two bulbs made in the same batch with the same materials, shipped and handled in the same way, fitted at the same time, and suject to identical use. In a way it is quite reassuring that that they lasted the same duration.
I find that it is entirely usual for identical bulbs bought and fitted at the same time to fail at about the same time.
Post #573252 25th Oct 2016 8:51am
Cheshire110
Yep, extra brightness bulbs of all makes generally claim a shorter life than standard equivalents too.
I always change headlight bulbs in pairs as it seems easiest when I'm doing one to do the other too Cheers, David
Post #574312 30th Oct 2016 9:36am
David above is definitely right there, all lighting in fact should ideally be changed in pairs unless it's an emergency. WeWillWin🇬🇧🇺🇸
Post #574333 30th Oct 2016 12:10pm
