![]() | Home > Puma (Tdci) > Puma Wash wipe stem |
Get a Mustuff seat runner set so you sit further back £40.00 job done. 2.4 90 XS
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
Mudstuff ![]() I had them in the ninety now in the 110 they help keep your knees away from the wheel ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5069 ![]() ![]() ![]() |
how tall are you!
im 6ft 2 and dont have that problem Mike |
foiloman Member Since: 23 Dec 2008 Location: Berkshire Posts: 9 ![]() ![]() |
I'm actually quite short at 4' 5" but have really long legs!
I'm going to give the Mudrails a go. Many thanks for the advice. 6' 3"... 2.4 110 XS |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 ![]() ![]() ![]() |
Hi,
You can make a cheap fix by yourself. If anyone is interested I can post some pics and hints how to make it. The trick is to lift the seat rail 3 cm so you can move the seat further back. Best regards, Janusz www.yahodeville.com |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2452 ![]() ![]() ![]() |
I did the same. couple of washers between the rails and box. |
evert Member Since: 23 Oct 2008 Location: antwerp Posts: 4 ![]() ![]() ![]() |
Hello, I'm quite interesed in moving my seat a little back. can you post some pictures?
many thanks, Evert |
I'm interested too, please post the pics
If you use Mudrails the seat is bolted about another 75 - 100mm further back
Hi,
Here are the pics of seat extension raills made by myself. The first shows the maximum I can get. ![]() ![]() Best regards,[/img] Janusz www.yahodeville.com |
