Home > Maintenance & Modifications > RDX relay sensitivity. (Trailer related) |
My vehicle also is all (RDX) LED (besides headlights), but my trailer has still incandescent lights. While I'm not a fan of using resistors in my vehicle - that's why I fitted the adjustable RDX relay - I would not mind using resistors for the trailers indicators, the trailer is not used very often, usualy only holidays.
What is against it using resistors in the trailers indicators if the RDX relay would not be sensitive enough? Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
24th Oct 2016 8:43pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20378 |
I could fit resistors to the trailer if I wanted to but ideally I don't, they would be very exposed and prone to damage.
And of course the heat issue. I guess there is only one way to find out and buy a set and go from there. I was just wondering if anyone already had any success of having to fit no resistors or other annoying extra wiring. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
24th Oct 2016 8:53pm |
I think you must bear in mind it would be dependend of which make LEDs other users may have in their trailers. I can image not all brands LEDs would trigger the adjustable relay in the same way, i.e. a positive result from a user using a different LED than you plan to use would not guarantee the same result with other LED brands...
Probably the best to buy the LED bulbs you plan to use in the trailers indicators and do a test... Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
24th Oct 2016 9:08pm |
I think that is what I'll do.
One of many many jobs on the 'to do list' now. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
24th Oct 2016 9:29pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5110 |
I hope this helps. I have a double axle trailer, a horse box and an Elddis Avante caravan, all are of 2014/2015 manufacture and all have incandescence bulbs fitted as standard on them all. I changed all my exterior lights on my Defender to led both TDi and TDCi. I found that neither worked properly with the relay supplied by WIPAC. On the TDCi I found that I needed to change the relay to that sold by RDX, as well as on the 200TDi but on that variant I had to obtain a special earth warning light, you have to phone them and ask for it to be sent to you. On the more modren Defender the RDX worked like a dream though I had to spend fifteen minutes fiddling with the little knurled screw to get it to work as i wanted it For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
24th Oct 2016 9:54pm |
I know LED's are much more sensitive to earthing issues than incandescent.
The little adjustment knob is quite sensitive, you can tell the difference between voltage at rest ignition on and running voltage which is approx 2v difference. This is why setting up the Relay I recommend to people it is done with engine running at operating voltage. I'm holding with the engine running and trailer light just off with no trailer on it will then work with trailer attached. Setting up this way keeps it more accurate and should help it detect the difference in lower LED draw of trailer LEDs. I will get around to testing sometime, evntually. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
24th Oct 2016 10:37pm |
