Home > Maintenance & Modifications > LR Cubby Box Cup Holder Mod
Avelingporter
Ideally I would like to replace the cup holder plastic insert in the LR oem cubby box to have a larger square shaped bin. I don't generally need the cup holder bit. If removing the standard cup holder the finish inside is rather tatty.
So...does anyone make a replacement plastic liner that is 'square' shaped to fill the void left by the cup holder molding?
Post #573113 24th Oct 2016 12:47pm
JOW240725
I've never seen a square tray to replace the cup holders, so suspect it will need to be a DIY job Thumbs Up James
Instagram @suffolk_rovers
Post #573117 24th Oct 2016 1:10pm
gilarion
Just an idea for what it is worth, but you could easily modify the Mud UK Cubby Box 6 Switch cubby box panel to suit your requirement; a little removal of the top section would give you a neat insert to replace the standard cup holder.
Or even more easily just remove the switch panel and turn it over to fit as it does not have a bottom! And you have a neat solution.
Size
A: 102mm
B: 250mm
C: 69mm (front)
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #573131 24th Oct 2016 2:07pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Stick a bit of carpet in there. Thumbs Up
Things don't rattle so much with carpet in there rather than plastic.
Post #573136 24th Oct 2016 2:38pm
