Home > Maintenance & Modifications > Radio aerial swap? how do you remove it?
Stacey007
Hello
My std aerial is a little bent at the top and also I would like to change it anyway.
Is there a how to? or where do I get at it? ideally could I just change the actual sticky up bit for a new part or would you swap it all?
Thanks
Post #572900 23rd Oct 2016 8:24pm
Need to replace the whole thing.
You can eithe swap like for like or consider a flexible one?
I never ever use mine, not a radio fan so never been bothered. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #572907 23rd Oct 2016 8:30pm
Stacey007
It there are how to anywhere?
I have the radio on more than anything else Smile
It works fine just looks naff
Post #572918 23rd Oct 2016 8:45pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Not much too it. Unscrew from the top, then push in through the hole in the wing. There is a "C" clamp which holds it in place but you can just pop it out of the clamp. The cable is soldered to the antenna. Unplug from the stereo end and tie a cable to the end so you have something you can pull back through the bulkhead for the new antenna's cable
Post #572932 23rd Oct 2016 8:53pm
If I remember rightly you remove the top nut and the whole unit can the removed from beneath.
It can be tricky to pull though the aerial cable through the bulkhead into the dash rear.
I'd recomend attaching a wire or similar to the old one when you remove to use it as a puller to bring the new cable and plug back through.
This would save you a lot of fiddling around. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #572933 23rd Oct 2016 8:57pm
Screbble
The removal should be straight forward, albeit a bit fiddly, if you follow the above good advice Thumbs Up
Definitely attach a draw wire when removing the cable, otherwise it'll be a PITA.
You will probably be thinking about DAB etc., however come the time when my aerial gives up the ghost, I'll be either going for a genuine LR replacement of something like this:
http://www.4x4overlander.com/product/hirsc...-defender/
Not cheap, but a good product.
I'd avoid buying something cheap and cheerful, unless you're not too fussed.
Best of luck Thumbs Up
Post #572975 23rd Oct 2016 11:31pm
^^^^ From what I have heard they are very good, yes, not cheap but quality cones at a price if that is your direction you'd like to follow. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #572983 23rd Oct 2016 11:55pm
NMBRPL8
Australia
What is the best replacement option for increasing AM reception over distances. Wiĺl an amplifier help increase current range of around 200km?
Post #573097 24th Oct 2016 12:32pm
kmac
Expensive is not always better.
This ebay one was well reviewed on this forum
It is amplified
http://www.ebay.co.uk/itm/Amplified-Replac...3a5685bdb5
I have the Bosch Autoflex which is amplified (unlike the Hierschmann one linked to above) and is excellent
Post #573168 24th Oct 2016 6:53pm
