Home > Maintenance & Modifications > Reverse light
MichaelHead
England 2006 Defender 90 Td5 HT Tonga Green
Reverse light
Hi all 2013 110 , reversing light stopped working I've checked bulb and fuse my question is where is switch and can I test it ?
Post #572755 23rd Oct 2016 6:59am
Defender marto
United Kingdom 2004 Defender 90 Td5 HT Oslo Blue
I had this problem on my td5. Bulb fine, fuse looks fine, so stripped out landy to get at switch on the top of the gear box, put in new switch, no joy Big Cry. After faffing around trying to fine the fault it turns out is was the fuse, it looked ok but it was not, so cheap option first swap fuse, you never know. But the switch to your is located under the access panel beneath the cubby box and looks like this. Marto
Post #572768 23rd Oct 2016 8:39am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
I had the same problem on my Puma 90 My 2010 .
I have fixed the problem with WD40 on the "ball" of the switch and on the connector .
Reverse Light Switch`07 on -Part # : LR005160
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #572905 23rd Oct 2016 8:27pm
