Home > Puma (Tdci) > Great loss of power & wont go over 60mph
Dieselhead
Can any of you guys help me with my serious loss of power please
My 2008 2.4 used to go like a rocket until a few months ago when there seemed to be a lack of power when I buried my right foot
Changed the fuel & air filters 1st with no difference
Never any fault codes pop up in ECU
Been messing with the thing on & off ever since
Now last week it decied not to rev above 3000rpm. It used to even when driving & stationary.
My EGR is mapped out & blanked . Changed the MAP & MAF Sensors for known working units from other engines Whistle
I spent a few hours yesterday pulling the wiring loom apart & checking. Bingo the 2 fat orange wires which feed the turbo unit were kinked to the point of nearly breaking Shocked . Sorted them & fitted all back together & went for a spin. No difference what so ever Big Cry
It will get upto 50/60 mph & will not go any more & the power goes. As if your towing a trailer with the brakes on. As if it goes into limp mode & starts to shut down
I am getting a squeel from under the bonnet also. Cant be the intercooler hoses as all replaced with new clamps & cooler blown out
Are my worst fears of impending turbo doom starting to rear its head??
My engine has done 93K
If so has any body got a good turbo they can lend me to try??
Thanks guys!! Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #572803 23rd Oct 2016 12:06pm
I'm afraid it does sound like the Turbo, can only really investigate further by physical checking.
Turbo wise, I'd recommend having a chat with Gary @ Alive Tuning.
He knows Turbo's inside out and can probably help you sort out issues remotely.
Hope that helps. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #572808 23rd Oct 2016 1:24pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Have you pressure tested the intercooler? 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #572813 23rd Oct 2016 2:43pm
Dieselhead
Thanks for that Steve.
I did pull of the pipe from the end of the turbo & give the shaft a wiggle. No play & the waste gate arm does park in the 90 degree position when switched off. When its running on tick over its pointing down.
What I have noticed since I have posted is some soot arround one edge of the flange where it bolts on the manifold. God knows what the underside looks like Confused
Would something as simple as replacing the gasket cure my probs??
I got no heat sheild in place as it broke off & no cat so can see easier
As for the intercooler..... No not had it tested. Hows one go about that??
Thanks for input so far Thumbs Up Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #572822 23rd Oct 2016 4:17pm
Turbo gaskets have been known to warp I believe.
I'm not sure if you'd be able to visually see if it is or not but there is ways of checking. (A bit beyond my scope of engineering knowledge.)
If there is soot in the area present, it does sound like a leak of gasses / pressure in the vicinity.
I take it there is no cracks in the manifold anywhere you can see?
Post #572830 23rd Oct 2016 4:39pm
Dieselhead
Reading up about turbo starting to fail it seems just like mine
One thing is about oily crap from your exhaust. That would explain the soot etc on the front of my trailer last motor way run Confused
Surly if the turbo has failed there would be no power at all??
I get no power after 2000 rpm. Have to remove it to have a look Sad Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #572904 23rd Oct 2016 8:27pm
Turbo and rpm are interlinked, a poor turbo will run I'm pretty sure but lacking power and boost.
Turbo should kick out max power around 2k rpm I think looking at rolling road graphs. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #572909 23rd Oct 2016 8:33pm
Double post. DELETED. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #572911 23rd Oct 2016 8:36pm
Dieselhead
Thanks for your input Steve
Seems I have some phone calls to make now Sad Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #572916 23rd Oct 2016 8:42pm
I've asked Gary the owner of Alive tuning if he could maybe help you on this here.
I'm not sure if he will be able or not, depends how busy he may or may not be.
Otherwise I'd definitely give him a call.
They do recon and upgraded too last time I knew and may even take you original turbo from you.
In the meantime. Hope all goes well for you, maybe just the gasket still. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #572920 23rd Oct 2016 8:47pm
If you have a diagnostic tool (eg Nanocom) you can check if you're getting boost very easily. It may be the infamous VCV on the fuel pump, not the turbo.
If you have no boost the engine will be massively down on power and it is unlikely you'll get to 60mph at all. Failure of the turbo is quite often caused by the actuator harness becoming chafed where it is secured to the block. What position is the actuator arm in when the engine is stopped?
Post #572949 23rd Oct 2016 9:31pm
Dieselhead
I have a nanocom which I will rig up tomoz
I pulled apart the harness yesterday looking for faults to find the 2 fat orange wires feeding the turbo kinked to the point of nearing breaking. I rejoined them & thought bingo my prob will be fixed. Wrong
I have changed the VCV valve which also solved nothing. I still have the old one though
My truck refuses to carry out the injector learn so god knows if its part of the prob
Like you say if the turbo was fully dead I doubt I would get to the end of the street
The arm is parked at 90 degrees when engine off. It points down when on tick over
Thanks Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #572954 23rd Oct 2016 9:54pm
Why does it need injector learning have they been refurbed or replaced?
If so and not gone through the learn process then that may have a bearing on it. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #572980 23rd Oct 2016 11:52pm
CR
Ireland 2011 Defender 110 Puma 2.4 CSW Santorini Black
it will be the turbo
Post #572995 24th Oct 2016 7:01am
Thanks
I'm working from memory so may be mistaken, but that doesn't sound quite as it should be.
The actuator should park in mid position, so that sounds ok, but IIRC fully up is the minimum boost position and fully down is max boost. I wouldn't expect it to the fully down on tickover, but I'd have to check mine to be sure. I may have mixed the two positions up.
If you can hook up a tool to see live boost pressures as you run, it might be insightful. When my harness failed, I was getting no movement of the actuator and it was parked at the minimal boost setting. With increased revs there was some boost (after all the turbo is still spinning) but very little. After I had repaired the harness, you can see the boost increase to max and be regulated there under appropriate driving conditions. What that max is will depend upon which remap you have, but typically it is likely to be around 2 atmospheres absolute pressure, so 2 bar or 28 psi. Some tools may not indicate absolute pressure, only relative, so may show 1 bar.
You should however get an impression of what the turbo is doing.
If it is overboosting it may be that the ECM is limiting performance to prevent damage, but I would expect to see some DTCs in this case.
As far as the harness is concerned, it is worth checking for damage at every point where it is secured to anyuthing under the bonnet. When mine failed, I found shocking damage to the harnes to the extent that if the actuator hadn't failed when it did, I think a vehicle fire would have followed in a few miles when the main alternator-to-battery lead grounded out - you could just see copper through the insulation where it was chafing. Appallingly bad design and build quality from our friends in Solihull!
Post #573048 24th Oct 2016 10:35am
