Home > Maintenance & Modifications > rear door not locking
Outlaw1
England 2010 Defender 110 Puma 2.4 USW Santorini Black
I have 2010 tdci 110 , the problem i have is that the passenger door behind the drivers locks if you push the button down manually , but does not lock or unlock with the fob , All the other doors work as they should . Any ideas what the problem iis and/or how to fix ?
Post #572372 20th Oct 2016 9:15pm
Do you mean if you push the door botton passenger side from outside if it's locked it'll jam and won't lock or unlock with fob? WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #572374 20th Oct 2016 9:22pm
Outlaw1
sorry , I have to use the button on the door inside the vehicle to lock/unlock that door , then i can use the fob to lock the remaining doors
Post #572380 20th Oct 2016 9:34pm
I see, looks like a strip down and further investigation is in order.
Sounds a bit like an actuator.
I mentioned what I did as I hadn't a similar issue with th same door but jams not won't lock or unlock.
It seems a bit of an issue with passenger doors for some odd reasons.
Does the door make any noise when you try to lock or unlock? WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #572381 20th Oct 2016 9:40pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
broken wires on hinged rubber boot where it goes into door pillar from door that's where I would be checking first tbh 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #572382 20th Oct 2016 9:41pm
Outlaw1
thanks for the replies and will have a look at the weekend now i have a starting point Thumbs Up
Post #572395 20th Oct 2016 10:36pm
ericvv
pj is right. All 110 SW get that (minor) issue after a number of years. Happened to my right hand second row door last year. Dealer replaced the wire and all fine again. Actually three weeks ago same issue with my left side second row door. Need to replace that wire now, and then the same thing will happen again in five years or so. Nothing more to it.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #572417 21st Oct 2016 5:34am
dorsetsmith
Post #572435 21st Oct 2016 8:30am
Outlaw1
Thanks all .Everything working As suggested a broken wire in the rubber hinge between pillar and door .
Soldered back together then shrink wrapped ,perfect. Saved £31.31 + vat the local stealer wanted for a new one.
Bow down
Post #572641 22nd Oct 2016 12:21pm
pj2106
Good stuff 👍👍 2008 110 2.4 XS Utility (Hagrid)
Post #572662 22nd Oct 2016 3:50pm
