Home > Puma (Tdci) > Aerial cable |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5054 |
There is a bit more clearance under there than the old aerial - but its tight and the ABS modulator doesnt help Mike
6th Feb 2011 9:54am |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Cheers for that |
6th Feb 2011 4:35pm |
cheers Mike, will do the same tomorrow and see if I can get a 33cm aerial in the space
6th Feb 2011 4:53pm |
if you open the blanked vent (where the heater intake is the other side) and put your hand in there you will be able to feel the existing and see the space.
My concer would be width than depth - but there seems enough to take an electric as i thought of doing it. For the sake of 6 ish screws - dead easy to check Mike |
6th Feb 2011 4:59pm |
