![]() | Home > Puma (Tdci) > Another faulty VCV ? |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 ![]() |
Check http://www.defender2.net/forum/topic48773.html
Are these the same symptoms, only longer? Why not changing the VCV as a preventive action, I think it's quite cheap.... |
lrMike Member Since: 26 Feb 2010 Location: Athens Posts: 177 ![]() ![]() |
Yes the symptoms are very similar but lasting much more than a second. Maybe 10 to 15 seconds.
I already ordered the vcv and the pressure release valve and I will post the results. Thank you anyway |
Got new information for us? I always appreciate feedback if problems are solved or still remaining, it helps others ...
New information as requested !!
Just before changing my VCV I actually saved the parameters (using nanocom evolution) of a short trip hoping that the described problem would appear. The conditions of the following diagrams are the following 1) Highway driving with only one driver and the tank half full. 2) As you can see from the 9th minute until 10:15 the throttle pedal is pressed to the metal (100 %) 3) However revs remain around 1800 – 1850 rpm 4) My speed remains between 80 and 84 kms/h 5) Here comes the interesting point. The comon rail pressure starts from 1000bar and does not increase at all. However it actually decreases a bit at about 900bar. During another trip where everything was normal the common rail pressure with full throttle was between 1400 and 1500 bar. ![]() Click image to enlarge My first step was to change the VCV. I tried to figure out how this could be done by myself but seemed to me nearly impossible to access the two hex bolts without taking the intake manifold out. So I took it to the dealer to change it for me. After about 200kms the response is perfect without any problems at all. The car seems to pull even better. The faulty VCV degraded the engine's performance even whenever it was not causing major problems like the one described above or the idle hunting. Last edited by lrMike on 5th Nov 2016 8:23pm. Edited 1 time in total |
Perfect analysis, congratulation! Where did you get the software from, I also own a nanocom but used to work with excel; not very comfortable....
Thank you my friend.
I believe this forum is all about helping each other. The software is free from the nanocom website. Its called nanocom CSV viewer. Nothing special. |
