dorsetsmith
![](templates/vbnew/images/spacer.gif)
14th Oct 2016 6:48pm |
I-Landy
Perfect thanks ![Thumbs Up Thumbs Up](images/smiles/icon_thumbs.gif)
15th Oct 2016 9:31pm |
Naf
When i swap away from stock, i go 10% less than max pressure when tires are hot.
IE, General Grappler have a max pressure of 51psi, i inflate to 40psi, then drive for 20-40km and then adjust the pressure to 44psi/3bar while they are hot. This way if i load up or drive on terrain that heats up the tire, i still have a margin before i start to flirt with the max capacity of the tire.
I also use 100% Nitrogen all the time... Its a waste the first time, as i need to vacuum the air out, fill, let it sit over night with the valve on the bottom, and repeat the next day. Oxygen is heavier than Nitrogen, and Nitrogen is a more stable gas than Oxygen.
2nd Feb 2017 5:32am |
