Home > Maintenance & Modifications > leg room
lozza
leg room
hi,i have a 99 110 hard top owned from new was going to be the" keeper "never going to sell etc,now all these years later with one knee partial replaced and the other on the way out i need more leg room,i have mudd bars and removed the bulkhead but at 6.4 i need to go back further,at the moment i can do about 1 hr driving before its killing me so my question is can the wheel arch that runs up to the bulkhead be cut back say 1ft and the seat moved back and fit a side window or should i sell my baby and buy a four seater and make up some loooong seat bars to get the leg room i need,also can a cruse control be retro fitted to a 99 td5
thanks
loz
Post #570578 13th Oct 2016 11:07am
It should be possible to cut back the box over the wheel arch to do what you want, since there is nothing underneath it at that point other than wasted space. It is in effect the space that is the secodn row passenger footwell on station wagon and double cab variants.
I have no idea how much work is involved but I doubt it would be too difficult, especially if you have already removed the bulkhead.
Post #570599 13th Oct 2016 12:34pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
It can be done, you'd probably need to add some new mounts to the chassis though. You'll need some way of bracing the rear of the seat mounts and you'll also need to move the seat belt mount points backwards if you're going so far back that the seat back is beyond any of the current mounting points. http://www.yorkshireoffroadclub.net/
Post #570609 13th Oct 2016 1:26pm
lozza
thanks for those replies i never thought about the seatbelt mounts
loz
Post #570657 13th Oct 2016 5:00pm
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
Also look at replacing the handbrake lever.
Using a Disco2 one and moving it next to the cubby box.
I'm only 5.6 & has made a world of difference for my left leg, especially on longer trips.
Cannot find the link to the site Sad but sure someone will post it.
 Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #570698 13th Oct 2016 7:27pm
AMBxx
I had a '03 90 with mudrails. At 6'2", I was comfortable with the seat all the way back. Your extra 2" would have struggled.
When I switched to a more recent 110, I was surprised at the extra legroom. In my new 110 SW with mudrails, I don't have the seat all the way back.
I'm not sure what's changed, it may just be the seat being slightly higher, but worth you taking a look (or someone more knowledgeable may reply).
Might be cheaper/easier to just replace your seats or findout what has changed.
Post #570763 14th Oct 2016 6:29am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
When I had my 07 110SW I had MUD seat rails fitted to get the extra legroom (6ft tall), I now have a 15 plate 90 SW and don't have any seat raisers but seem to have adequate leg room, not sure what has changed. I don't think I have shrunk Very Happy
Post #570773 14th Oct 2016 7:53am
Roy5695
You can also replace the handbrake with one from a Range Rover Classic, just a couple of holes need to be drilled, no change to the cable or anything. This will increase the left leg room no end, also for the right leg a slight improvement is to get fabric or leather door grab handle, these will fold flat and allow and extra inch on the right side.
defender90xs blog spot has very good walk throughs on the hand brake. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #570775 14th Oct 2016 7:58am
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
@lozza ...
Post #570834 14th Oct 2016 2:25pm
roel
Cruise controll is easy to install the ecu is programmed for it. Roel
2003 90 Td5 (2009-now)
Post #570860 14th Oct 2016 5:17pm
miker
I'd love to do an electric handbrake conversion on mine to regain that space in the footwell!
Post #570904 14th Oct 2016 8:16pm
Roy5695
By fitting the range rover classic handbrake you gain all that space, it relocates the handbrake to the side of the seat. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #570924 14th Oct 2016 8:57pm
Bushpig
Found the link...
http://defender90xs.blogspot.co.uk/2013/09...lever.html Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #570962 15th Oct 2016 6:32am
miker
I like it, but not sure I'd want to lose my middle front seat. May have to get one and have a play with mounting options.
Post #571195 16th Oct 2016 10:48am
