Home > Td5 > No battery light - won't turn over
Soupy
I have a 2005 td5 that won't turn over. There is no battery light on the dash, all the other lights work as normal.
If I bypass the SM relay it will fire up for 2 seconds before it shuts off and kicks in the immobiliser. I've had a look round the earths and can't see anything. I tried a new relay, made no difference.
Any ideas??
Post #569867 10th Oct 2016 12:36pm
dorsetsmith
Is fuse 15 ok bulkhead fuse box ? supply to battery light and on to ALT
Is engine immobilisation enabled to work ?
Post #569871 10th Oct 2016 12:53pm
Martin
Site Admin
In my experience that means the immobiliser is still active.
Any immobiliser/alarm lamps active on the dash at all?
There's the red LED in the speedo, plus the red engine symbol with a lightning bolt through it (this gets triggered when the immobiliser is not deactivated before starting).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #569873 10th Oct 2016 1:01pm
Soupy
No immobiliser lights. I can switch the immobiliser off with Hawkeye (I think - I switch it off but when you go back in it says it's on again).
Post #569878 10th Oct 2016 1:39pm
Martin
Site Admin
Check the fuses on the bulkhead, particularly 8 -> 15.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #569885 10th Oct 2016 2:05pm
Soupy
All fuses are good.
I noticed that if I run a wire from the alternator earth to the body I get a battery light but still won't turn over.
Post #569893 10th Oct 2016 2:56pm
Soupy
Eejit award for the day goes to ME!! Rolling with laughter
Fuse 8 - immobiliser = blown.
Cheers!! Thumbs Up
Post #569899 10th Oct 2016 3:21pm
dorsetsmith
from the alternator body to the body work ? as alternator earth throw its body work
have you checked chasers to transfer box earth ?
Post #569900 10th Oct 2016 3:21pm
Soupy
Still no battery light though....
Post #569901 10th Oct 2016 3:21pm
Soupy
What do they look like and where exactly are they. There was no earth that I could see on the transfer box, there is now because I put one on. transfer box -- chassis.
Post #569905 10th Oct 2016 3:54pm
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
Blue relay in the drivers seat box , check this is ok . Had same issue with mine
And turned out it was this relay Have fun be happy
Post #569907 10th Oct 2016 4:07pm
dorsetsmith
main earth from battery to chassis to transfer box
chasers to body work drivers side
Post #569908 10th Oct 2016 4:09pm
