![]() | Home > In Car Electronics > Voltage drop and other rewire queries. |
That does sound like overkill and can only think that there's something not quite right with your calculations. Standard automotive 28/.30 2mm cable is good for 17.5amps and the volt drop over the length of a Defender should be negligible. Darren
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 333 ![]() ![]() |
Hi,
Im using this calculator and recommendation to keep below 4% drop. http://www.12voltplanet.co.uk/cable-sizing-selection.html |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20737 ![]() ![]() |
I'd tend to agree with LRA above, I'd go for 2.5mm thinwall myself.
Earth should be the same dia, the earth loop is just as critical as the live feed in the circuit. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Well I just found a permanent live and earth in the rear drivers side behind the light panel so I may well just use that, looks like a 12 v feed for an aux socket. Will combine it with my new speaker panels.
There's a thread about that. it's 20A fused and I'm pretty sure it's 2mm^2.
http://www.defender2.net/forum/topic20319.html LED worklights will be much less sensitive to voltage drop than standard ones because they are regulated so constant brightness until they stop working. |
Thanks for the help on this. I am going to use that feed in the back for a permanent 12 volt feed but might add a local illuminated switch so I do not leave it on.
I now have an issue wiring up my carling switches.They have three terminals that control the basic switch (on/off) and then two sets of terminals that control the large light and the small 'bar' light. I think I should have the bar light LED switching on with the vehicle lights (easy) but would like the bigger light to illuminate when on. The question is do I just jumper the switched live to the lamp live or is there a circuit inbuilt to do this like on other switches? Thanks James |
