Home > In Car Electronics > Double DIN Dash Issues? If you have one fitted, please help! |
Edzi Member Since: 20 Sep 2015 Location: London Posts: 279 |
Good tip with the hairdryer! Thanks.
19th Sep 2016 6:54pm |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 |
That's a good point about the tabs.
For fitting, I find it useful to leave the electric window switches hanging out so you can get a finger through to support the plastic brackets those tabs click in to. Otherwise the brackets bend back and spring forward again, pushing the facia back out. http://defender90xs.blogspot.co.uk/ |
8th Oct 2016 3:47pm |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2925 |
I have had my dash apart so many times I lost the metal clips. I basically have now drilled a hole in the headunit case, and then with the clock and vents out, I attached a cable tie to the mounting hole that the support bracket (which you remove) bolts too. Pull this tight and the fascia etc all sits perfectly in line with the sides. Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
8th Oct 2016 3:58pm |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
Andy,
that´s a good one. Brilliant. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT´s, Recaro CS´s, anorak, wellingtons |
8th Oct 2016 9:06pm |
big110 Member Since: 02 Nov 2016 Location: Sweeden Posts: 342 |
gorgeous job on this! |
2nd Nov 2016 2:40pm |
