Home > Td5 > Exhaust Manifold
Deerfold
United Kingdom 2004 Defender 90 Td5 HT Caledonian Blue
Exhaust Manifold
Hello all, I have the invevitable warped manifold on the defender, the question is other than the alisport manifold where do I get a skimmed and fettled manifold with longer studs, that doesnt cost the earth. I have tried irb with no reply. Fortunately as of yet I haven't got any snapped studs!!
Post #569204 6th Oct 2016 8:53pm
mk1collector
I might be wrong but can't you just remove the manifold and get it skimmed flat at an engineers? It shouldn't warp again surely. Ray
My build thread
Post #569219 6th Oct 2016 10:19pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Agreed, it should not warp again and you can get the longer studs separately. And more importantly, how'd you know his name was Shirley? Rolling with laughter 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #569224 7th Oct 2016 12:29am
Deerfold
Indeed guys, that would be an easy option but I can't really be without the truck, hence remove the old and replace with an already fettled one.
Post #569233 7th Oct 2016 5:55am
You could buy a second-hand manifold and get that skimmed and de-webbed before dismantling the vehicle. Studs etc are easily obtainable, but if you de-web the manifold there is probably no reason for using longer or stronger studs.
I have a spare un-modified TD5 manifold in good condition (and seemingly unwarped) surplus to my requirements which I haven't got round to advertising on here yet, I'd probab;y be looking at something around £45 plus p&p if it is of any interest. I bought it to use on my Disco 2 but then bought one already machined.
Post #569270 7th Oct 2016 9:07am
Deerfold
Thank you very much for the offer but I really want a manifold that has already warped and then fettled as it is a lot less likely to go again!!
Post #569301 7th Oct 2016 11:42am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Mine went a little while back, a friend had purchased a genuine warped manifold from eBay that the seller had de-webbed then machined so i was able to buy that from him. It's held up perfectly on a 3,000 mile trip around Europe last month, despite being pushed hard for long periods in the Alps. The only thing to note is that the paint isn't high temp so will peel off on the first long joruney.
http://www.ebay.co.uk/itm/LAND-ROVER-TD5-M...XQ1ZhTev3~
At the same time I fitted the Wurth studs that several people recommended, they are a Mercedes part but fitted perfectly.
http://www.ebay.co.uk/itm/like/30122372977...rid=229508
2 of the original studs had sheared in the head but once they were out it was a very simple job. If you don't already have them then buy a set of easy outs and a couple of 3mm and 6mm drill bits as a precaution.
There's a handy how-to guide that I used, the workshop manual was useful for the torque settings also. The only bit I did differently was to loosen the turbo-exhaust bolts but leave it in situ and split from the manifold in the engine bay.
http://alex.threlfall.me.uk/?p=19
Post #569470 8th Oct 2016 10:49am
Deerfold
Thank you, that is great, I shall get one ordered up and and the studs. I have some easy outs but I may just get a couple of spare drill bits!! Do you have the torque settings? Many thanks again.
Post #569481 8th Oct 2016 11:50am
Harry.O
The manifold studs are 25nm as are the turbo to manifold ones. Afraid I can't remember the other ones off hand.
http://workshop-manuals.com/landrover/defe..._manifold/
The Haynes book of lies has a page of all the TD5 engine torque settings if you have one of those Very Happy
Post #569500 8th Oct 2016 2:14pm
chinnus
2001 Defender 90 Td5 ST Coniston Green
That's what friends are for eh ? Harry.o
Post #570342 12th Oct 2016 1:38pm
mk1collector
Thread resurrection time Big Cry I think my exhaust manifold has finally warped Big Cry starting this morning I got a sort of high pitched whistle when accelerating for a few minutes until the engine warms up a bit then it stops, then when the engine cools down again we have the same again. I'm guessing this happens because the manifold expands a bit when it warms up so seals the gap. So onto my question, there are the de-webbed versions still available on eBay and there seems to be quite a few stainless versions now too so which are best to buy? Hoping to get it sorted quickly as people keep thinking I'm wolf whistling at them Rolling with laughter
Ray Ray
My build thread
Post #632095 18th Jun 2017 5:14pm
cobra_mark
United Kingdom 2000 Defender 90 300 Tdi SW Barolo Black
Would you advocate de-webbing a manifold if it was coming off for any other reason, got to sort out my core plug under the manifold on the side of the head? Certainly de-webbing would make it easy to remove a core plug if it leaked again.
Post #632107 18th Jun 2017 6:48pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Have heard much about de-webbed manifolds. What is it exactly? Any before and after pics to help the less initiated visualise what is going on? What is the benefit of doing such a thing too?
Post #632161 18th Jun 2017 10:27pm
bankz5152
De-webbing and re-skimming and re-fitting with longer studs & spacers/washer and copper flashed nuts means a few things
De-webbing - The idea is the manifold can move/flex under the heat created and prevent it from warping
Re-skimming - Gets a warped manifold flat again
Longer studs - Enables you to fit spacers/washers which allow it to flex more
Copper flashed nuts - Means you can remove the nuts without sheering studs to remove the manifold much more easily.
Thats the one I have fitted to my 110, no issues what so ever so far.
Post #632205 19th Jun 2017 10:16am
