![]() | Home > My Defender > An Anoraks Tdi Defender 90 |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Looking Good
![]() Self confessed mileage hunter ![]() |
Thanks
![]() I hope to get time to replace a leaky sump gasket at the weekend and then it's sound proofing and interior trim. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Well, I started replacing a leaky sump gasket at the weekend but rain stopped play, so I finished today. As is often the way though, what should have been straightforward ended up being a complete sod of a job.
![]() Click image to enlarge The first problem was that I couldn't get the sump off. It did come off eventually, after much prying and levering, and it was immediately obvious what was wrong. Whoever had been there before had stuck the sump on with some sort of silicon ![]() ![]() Click image to enlarge With everything finally nice and clean, I positioned the new gasket ready for fitting. I know that there are several schools of thought about gasket sealant but this cork gasket came with explicit instructions not to use any. They also suggested using a small amount of superglue to hold it in position whilst fitting, which is what I did: ![]() Click image to enlarge The bolts are just to align it whilst the glue sets. All of this worked very well and getting the sump back into position was relatively straightforward. I also fitted a new sump plug and washer. The next issue was removing the old oil filter, which I think had been tightened by a gorilla. It did finally relent and, after cleaning up the mating face, a new filter was installed. I then re-filled with oil and started it up and all was good. Well, mostly. There was a small weep from the filter, which was annoying. There was no obvious reason why and, as it's only slight, I'm going to run it as is for the time being. I may well change to a different filter brand next time (both old and new were Mahle) to see if that makes a difference. On a more positive note, I've spent a bit of time cleaning and painting the three access panels to the seat box. I've also taken delivery of a box of Silentcoat and a Hardura mat set. There is no matting in it at all, at the moment, and it's like driving around inside a drum, so sound proofing is high on my priority list! Other minor victories include removing a very rattley and worn turbo heat shield (not sure what to do about that yet) and tightening a slack exhaust clamp where it meets the turbo, which has stopped it blowing. Jobs added to the 'list of things to do' include repairing the wiring to the rear washer pump (damaged whilst removing dip stick ![]() I hope to get to the more fun stuff soon... Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 29th Jul 2017 4:38pm. Edited 1 time in total |
Yeah, I did put some new oil on the seal. Darren
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10867 ![]() ![]() |
More tinkering time today:
Fixed the indicator - it's a worn housing so I've tweaked the contacts as a short term fix as all of the lights are on the cards for replacement. Tried to fix the horn but concluded that it's dead and needs replacement ![]() Had a quick look at the low fuel light but couldn't find anything obvious. Then got bored of just fixing things and decided to bolt some stuff on instead. Started simple with some stainless screws for the headlight surrounds and wingtop vents: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Not quite stainless, but some blackened screws for the intake vent to replace the counter sunk wood screws that were there ![]() ![]() Click image to enlarge I then fitted my favourite grab handles to the rear crossmember, which was more involved than expected. I had to remove the rear light guards, which meant removing some of the crossmember tab bolts and left a variety of holes in the bodywork ![]() When I finally got to the grab handles, they too were secured with stainless bolts, but this time into mounting plates with tapped holes for inside the crossmember. ![]() Click image to enlarge And the things finally in place: ![]() Click image to enlarge At some point, the crossmember, handles and tow bar will get re-painted as it's all a bit flat at the moment. Cosmetic stuff like that is a lot further down the priority list, though. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 29th Jul 2017 4:33pm. Edited 1 time in total |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Full set of lights here sat in a box
Yours if you're passing |
Thanks Matt, but I've already got a set in a box ready to go. I just need to convert the wiring to Econoseal connectors, for which I've just ordered all of the bits. Darren
Another days' fettling has seen some tangible progress and a dent in the stack of parts I've been collecting.
First up are the seat box access panels: over the last few days I've been diligently spraying them with light coats of paint - Smoothrite on the inside faces and enamel on the outsides over a zinc primer base. ![]() Click image to enlarge New sticky back neoprene seals and job's a good 'un: ![]() Click image to enlarge Next up was replacing some of the switchgear - the infamous headlight switch and also the indicator stalk. ![]() Click image to enlarge ![]() Click image to enlarge Comparing the new with the old reveals the weakness of the headlight switch. ![]() Click image to enlarge The old switch shows quite a lot of corrosion to the contacts and, although difficult to see, the plastic was discoloured due to heat: ![]() Click image to enlarge All of the new contacts have been given a blast of electrical contact cleaner before use but eventually I'll rewire the headlights via some relays to spare the switch of the load. Interesting fact of the day: all of the nuts and bolts that secure the column switch gear are Imperial ![]() I also paid a paid a visit to Challenger 4x4, which I've never used before despite being just down the road. I picked up a new horn for a very reasonable price but I'm painting the bracket before fitting, so that's a job for tomorrow. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 29th Jul 2017 4:26pm. Edited 2 times in total |
After painting the horn bracket (and those for the radiator as it was easy to do at the same time) yesterday evening, it had dried overnight and was ready for fitting. Complete with new Bearmach horn:
![]() Click image to enlarge And all bolted into place with new stainless bolts: ![]() Click image to enlarge The wiring had been re-routed to suit the poorly installed air horns so that had to be rectified, which included a new rubber grommet where it passed through the inner wing. Went out for a run this morning and took the opportunity to get some decent overall pictures. First up, the rear to better show the new grab handles and the lack of light guards: ![]() Click image to enlarge And finally for now, a typical 3/4 front: ![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 29th Jul 2017 4:21pm. Edited 1 time in total |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 512 ![]() ![]() ![]() |
Looks fantastic! It's given me a few ideas inc. side steps and I like those grab handles too!
![]() '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
Thanks
![]() The grab handles though, are something else. They are actually a 'deluxe' item from Series Land Rover days and are reasonably rare. I've always liked the look of them and this is the third Land Rover that I've fitted a pair to. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
After completing the transfer online, I fitted my cherished plates today:
![]() Click image to enlarge The beauty of this sort of thing on a Defender is that it really does blur the age ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 29th Jul 2017 4:17pm. Edited 1 time in total |
Great on going transformation
