Home > Other Site Sponsors > Keep the winter rust at bay with ACF-50!
oilman
With summer coming to a close, autumn is just around the corner. Of course, once autumn is out of the way, we've got winter to look forward to, and we all know what the greatest danger to our vehicle over winter is...RUST!
Opie Oils can help you keep the rust and corrosion at bay, thanks to our new star product, ACF-50 Anti Corrosion Formula and Corrosion Block. If you've got a car, motorbike or boat that you want to keep in pristine condition, then you may want to have a look below...
ACF-50 Anti-Corrosion Formula
ACF-50, Anti-Corrosion Formula, is a state of the art, anti-corrosion/lubricant compound, that has been specifically designed for the Aero Space Industry. It can be described as an ultra thin fluid film compound which must be applied on an annual basis. ACF-50 actively penetrates through the corrosion deposits to the base of the cell where it emulsifies and encapsulates the electrolyte, lifting it away from the metal surface. ACF-50 then dispels this moisture and provides an atmospheric barrier which prevents any further moisture contact, thereby keeping the cell inactive.
This compound continues to actively penetrate and "creep" into the tightest of seams, lap joints, micro cracks and around rivet heads, dissipating the moisture, even salt water, in these corrosion prone areas. These unique abilities of ACF-50 remain effective for 12 months, gradually disappearing as it is chemically consumed.
- Approved for use on Electronics
- Non-Flamable, non-toxic
- Contains NO solids
- Remains "ACTIVE" for up to 12 months
- Film thickness is 0.00026
- A blend of ultra-pure base stocks and speciality corrosion inhibitors and surfactants
You can find further information and pricing HERE. Don't forget to use your forum discount to get an additional 10% off your order!
All in all, this is a fantastic product that we are proud to stock - designed as an "all round" corrosion inhibitor that adapts to whatever task you throw at it. Available in a 13oz aerosol, 1 quart bottle (with refillable pump spray), 4 litre container and even a 20 litre drum which is perfect for the workshop.
After a slightly thicker "grease" for your electrical contacts or wheel bearings on your trailer? Have a look below for the next great product from the same guys.
Corrosion Block Anti-Corrosion Formula Grease
It's no secret that equipment downtime, repair and replacement are expensive. It is also no secret that regular scheduled preventive maintenance is cheaper than the repair or replacement of expensive equipment. Available in a 57g tube and a 454g tub, you can view it HERE.
In these days of dwindling maintenance budgets and closer scrutiny of operating costs and procedures, you can show a real saving through preventive control of corrosion.
Corrosion Block can be described as a clean, clear, ultra-thin fluid which leaves a non-greasy atmospheric barrier to protect the base metal on interior surfaces. Corrosion Block leaves no gummy residue because it contains no wax, resin, tar, asphalt, silicone or telfon.
Corrosion Block anti-corrosion compound is a state-of-the-art material developed for the marine industry. Corrosion Block has three superior features:
1. Superior Anti-Corrosion compound
- Kills corrosion in progress
- Prevents new corrosion cells from forming for 12-18 months
2. Works as an excellent penetrant
3. Performs as a light lubricant very effectively
You're probably thinking "that's great, but can it isolate the corrosion byproduct from my beloved electrical circuits?" Well, yes. yes it can.
As well as offering the mentioned benefits, it also has many electrical uses. Corrosion Block has the ability to remove moisture, combined with its excellent penetrating and strong dielectric properties, have brought a number of electronics 'back from the dead' with just one application. The Corrosion Block removes the moisture from the corrosion byproduct, then isolates the corrosion byproduct from the electrical circuit. Corrosion Block can be used in many different electrical and electronic applications without fear of damage. Corrosion block will not harm paint or plastic surfaces.
We're sure you'll find this new range of anti-corrosion products to your liking - at Opies, we don't stock a product unless we have complete confidence in it, so it's got our seal of approval. If you fancy a look at the full range of our rust preventatives and anti-corrosion treatments, you can find them all HERE.
That's about it from us for today. As always, should you need any advice, please feel free to give us a call on 01209 202 949 or drop us an email to sales@opieoils.co.uk and we'll be happy to help. We're in the office Monday to Friday, 8:30 - 5:30.
Until next time!
-Oilman Use the code DEF2 and get 10% Club Discount
View Opie Oils Current Offers Here > >
oilman's website: http://www.opieoils.co.uk/ - register for news and offers
email: sales@opieoils.co.uk
phone: 01209 202944
Post #565539 21st Sep 2016 10:35am
xtr2turbo
United Kingdom 2016 Defender 110 Puma 2.2 USW Corris Grey
Good timing
Just ordered
I find best to buy in bulk size and apply as a fine mist with a spray gun
David
Post #565564 21st Sep 2016 11:44am
oilman
Hi David
Thanks for the order.
Tim Use the code DEF2 and get 10% Club Discount
phone: 01209 202944
Post #565567 21st Sep 2016 12:12pm
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
Yes good timing. Just ordered some ACF-50. Thumbs Up
Thanks
John
Post #565577 21st Sep 2016 1:29pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Get some sprayed under the body capping's, did my 07 110SW when new and never had any corrosion problems Smile
Post #565600 21st Sep 2016 4:59pm
Zagato
"Get some sprayed under the body capping's, did my 07 110SW when new and never had any corrosion problems"
Good man Thumbs Up Wish everyone would do that, amazing how many still don,t realise it,s bare metal under there Sad Don,t forget hinges, bonnet to bulkhead hinge where spot welded to bulkhead, rivets, under bonnet etc etc etc...
Didn,t realise you sold ACF-50 Tim, have only just put a big order in with someone but will go through you next time Thumbs Up
Post #565602 21st Sep 2016 5:10pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
I sprayed it along every seam and seal including hinges and brackets. Will be doing the same annually as a few mins work and minimal cost has to be worth it, IMHO.
Post #565604 21st Sep 2016 5:15pm
Make sure it's wiped off of panels though as it goes a bit gluey and then can attract dust / dirt to stick.
Other than that it's great stuff. Thumbs Up Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #565605 21st Sep 2016 5:18pm
T140
Scotland 2007 Defender 90 Td5 HT Zambezi Silver
Hi, how much is needed to do a 90. nobody is perfect but being Scottish is a start
Post #565608 21st Sep 2016 6:05pm
Zagato
Depends if you spray or largely paint on with brush but one can should last at least a couple of years if you only do the main bits on the vehicle twice in a year. I used to use one aerosol per Defender for one treatment Shocked One can lasts me about two Defenders now being more precise and doing door hinges, all the engine brackets, interior bits, rear crossmember, rad surround, air intake screws and rusting spring clips, headlight rims, slam panel, bonnet catches, wiper swivels, etc etc as well as rear cappings, mirror arms, and the two rear window latches, rivets etc etc. anything that corrodes basically including the screws on headlight and front grill surrounds, rear step, tow bracket and electric socket, rear door handle and bit you push key into etc etc the list goes on, rear door inner grab handle screws and the two on door latch, seat frame bits, footwell fasteners, and other screws holding bits of metal trim on inner A post etc etc the list goes on...clutch cylinder and the vin plate mounting block behind it and other block further in next to it and the top bolts back top of wing.... Too many bits to describe easily but just spray and/or get a little brush on as many metal bits as you san cos it will all be corroding after only a few years otherwise...
Post #565645 21st Sep 2016 7:48pm
Conan
Belgium 1996 Defender 90 300 Tdi HT Coniston Green
Great info! I just ordered me some.
Post #569055 6th Oct 2016 7:23am
ericvv
Zag, question. How do you get it to penetrate behind the body cappings? Especially the cappings on the back of the truck left and right of the safari door, and those on the rear sides of the truck?
I don't see much, if any, gaps there on mine.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #569060 6th Oct 2016 8:03am
oilman
Hi
phone: 01209 202944
Post #569061 6th Oct 2016 8:08am
oilman
Eric
Hi Eric
You might be better off with Dynax S50
http://www.opieoils.co.uk/p-73830-bilt-ham...n-wax.aspx
The lance that comes with it is pretty slim so you can get it through small gaps and the head of the lance makes it spray in lots of directions.
phone: 01209 202944
Post #569067 6th Oct 2016 8:30am
Conan
Hi Tim,
How about using ACF-50 with a spray gun (with a compressor) with one of those flexible extension nozzle? Like they have in the Dinirtol kit.
Post #569070 6th Oct 2016 8:40am
