Home > Puma (Tdci) > Indicator problem
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Indicator problem
After towing a trailer, my indicators stoped working (panic lights work normaly).
this could be coincidence, or coursed a short and damaged something.
I checked the 5Amp fuses they ware okay.
Were to look at next?
Post #568869 5th Oct 2016 2:15pm
dorsetsmith
5 amp fuse ?
Post #568882 5th Oct 2016 3:00pm
TopQ1967
Thank you for the overview. Makes a lot clear.
Than I am looking to the wrong fuses.
What row/No is it?
Post #568886 5th Oct 2016 3:34pm
VeeTee
Netherlands
Probably fuse F2 or F30 in the steering column fusebox?
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #568898 5th Oct 2016 5:12pm
TopQ1967
Thank you all iT was F2
Post #568902 5th Oct 2016 5:32pm
VeeTee
Netherlands
Thumbs Up
But then the next question arises: what caused the fuse blowing? Short circuit in the trailer wiring, water or dirt in the towing socket, or .... ? Cheers, Vincent
MySite
Post #568903 5th Oct 2016 5:36pm
dorsetsmith
good at lest it fix Thumbs Up
Post #568915 5th Oct 2016 6:15pm
The reason for the fault should be further investigated though. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #568942 5th Oct 2016 7:20pm
