![]() | Home > Off Topic > Solenoids v Relays |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
I can't belive I beat to it by Mal
![]() ![]() Glyn ![]() ![]() |
![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
When I first fitted it I hept an eye on it (don't have a thermometer) but just put my hand on it to see what it is like over long distances and it was normally only warm- mine is in the battery box with no airflow to assist any cooling but I don't think it needs any. Glyn ![]() ![]() |
Thanks Glyn.
Ours is mounted upside down in battery box. Suppose battery box wall acts as a giant heat sink. Upside down easier to get to terminals. Brendan |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
If an electrical device such as a relay is getting hot (as in prelonged touch would hurt the finger) its a sign that something is wrong, i.e wrong size slected or drawing too much current due to a fault. The contacts will burn up, causing a high resistance to the point that the device would either melt or not work. A 200A relay should be warm / tepid but not hot, the coil will generate some heat, but not much. |
