![]() | Home > In Car Electronics > LED worklights, would you wire via a relay? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20765 ![]() ![]() |
Less than 3A draw at 18w more like 1.2A - 1.6A.
I presume you mean a pair through. Most switches are rated at 6A minimum but should be fine directly switched, but a relay would do no harm either. Completely up to you. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
I wouldn't worry about it, unless using a relay gives you some other sort of benefit that's useful to you like changing from high to low side switching, or control from something else.
I have some changeover switches inside my rear door that switch the worklight and a 12V DIN socket on/off/remote. That means I can have the socket controlled from the dash switch, or the light controlled from the dash switch, or both, or either of them controlled locally. Most of the time I have the socket off and the worklight as remote, but if I wanted to put a beacon in temporarily then I could have the worklight manual and the beacon controlled from the dash for instance. Next step is to have a 12V socket that's on/off/ignition. |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 333 ![]() ![]() |
I love the idea of the 12 volt being on off ignition
It's not that hard, you just need two feeds in to a changeover switch.
