![]() | Home > Puma (Tdci) > Wild bear Diff Guards, I've mixed up the brackets |
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 237 ![]() ![]() ![]() |
Puma 90 diff Guards front and back
If any one has fitted these, I gone and mixed up which bracket went with which To save me climbing about underneath when I go to fir these be appreciated if any one knows There is a flat top plate with round holes or a slightly gimped top plate with oval holes in ![]() Click image to enlarge ![]() Click image to enlarge |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
There are a few people on this thread that recently fitted them front and back so should be able to help
http://www.defender2.net/forum/topic35405-30.html |
Sorted
As per my pictures, they were paired correctly Took all in 4hrs - 9.15am put landy on ramp in mates workshop - 9.30ish make cups of tea - 9.40ish fetch breakfast rolls - 10.00 start working on diff guards - 1.00pm finished ![]() I found the diff gurds fit not to bad, insted of fitting the top bracket to the main body of the diff guard with the bolt facing down (as per pictures) I screwed the bolt facing upwards throught he treaded section of the diff guard. This enabled the bolt to be held in place and made it easir to locate and support the top bracket. I then used a nut (not supplied) to pull and fix the parts together Soooooo much easier. Also the supplied bolts for the rear diff guard are not correct for my Puma, the pitch of the thread was wrong, the predrilled holes in the diff are M10 - metric fine (the bolts supplied were neither metric fine or UNF - could not work out what they were) Hope this helps someone else |
