Home > In Car Electronics > LED Reversing Light
Simali
United Kingdom 2004 Defender 110 Td5 CSW Zambezi Silver
LED Reversing Light
Anyone found a decently bright LED reversing light solution 2004 110 CSW (Called Yoda)
Post #568081 1st Oct 2016 7:43pm
RDX LUX or Wipac you won't go wrong with.
I have the former and more than happy with it. Thumbs Up $W33T $0U7H3RN $UG4R
Post #568082 1st Oct 2016 7:47pm
Stacey007
I will soon (hopefully next week)
Be changing my std rear lamps for Wipac LED's
Assuming it goes to plan I may also look at adding another fog and reversing light to give this look.. (these are not wipac though) but would give more reversing light?
The alternative would be to fit an extra light (lazer light) on the rear somewhere?
Post #568084 1st Oct 2016 7:50pm
JWL
I doubled mine up as above and chucked some of these modern sree bulbs in and I'm happy with the effect, I can see to back down our street to my parking space a lot easier now Thumbs Up
Post #568089 1st Oct 2016 8:07pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
There are a few ideas in this thread Thumbs Up http://www.defender2.net/forum/topic32834.html
Post #568093 1st Oct 2016 8:37pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
NAS Spec lamp, ridiculous CREE LED bulb x2 Wink
Post #568094 1st Oct 2016 8:40pm
^^^^ Okay, for reverse as non obligatory but not legal for other obligatory road lights. $W33T $0U7H3RN $UG4R
Post #568097 1st Oct 2016 8:44pm
Disco_Mikey
Pics might help Embarassed
Post #568098 1st Oct 2016 8:45pm
Disco_Mikey
custom90steve wrote:
^^^^ Okay, for reverse as non obligatory but not legal for fof or other obligatory road lights lights.
Isn't that what the OP is asking for? Advice on upgrading the reverse lights Confused
FWIW, I also have bright LED CREE bulbs and NAS lamps for my fog and tail/brake lights. Never had an aisle with traffic plod nor MOT test Thumbs Up
Post #568099 1st Oct 2016 8:47pm
Stacey007
Another option..
I fitted this which does help getting VERY close to things without.... Bump Smile
It also has built night vision 'lights'
Post #568103 1st Oct 2016 8:56pm
JOW240725
I doubled up on the standard Wipac LED Reversing and fog lights. I guess it doubles up the light and is better also puts light both sides which is better. The reversing lights have 'blown' twice now and this set has to got back again, all the others are fine, just the reversing.
The other option is the Scenelight LED Strip which mounted in place of the rear washer jet or one each side at high level gives great light. DO a search on Scenelight.
Since taking the photo I've actually had the fog and reversing light swapped around so the fog is on the inside to move further away from the indicators. James
Instagram @suffolk_rovers
Post #568110 1st Oct 2016 9:17pm
ericvv
Wired as a worklight with switch on the dash, so you can use it when needed for reversing.
Off position
On position
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #568141 2nd Oct 2016 3:55am
Bluest
I think member CY88 has a combined LED reverse/fog which he said was very bright on another thread. Standard NAS size so you can have symetrical 2 reverse and 2 fogs without needing any extra units. 2007 110 TDCi Station Wagon XS
Post #568148 2nd Oct 2016 6:25am
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
Mine had Doubled up old style lights so had to cover the holes when I went LED
Post #568313 2nd Oct 2016 8:16pm
