Home > Puma (Tdci) > My Defender 90 in for some modifications
Page 8 of 8 <12345678
SkyFallSilver
Kuwait
it covers the airbox from dust and leaves, i do get a check engine light because dust gets in and my car goes into limp mode. 2016 Defender 90 Adventure Edition
Post #567471 28th Sep 2016 9:57pm
spirit461
Philippines
Hi Sky,
You said that you removed the Twisted 30mm spacers because of the looks and also because of some wheel vibration at 100kph. I have noticed that you've installed back 30mm wheel spacers but this time from TerraFirma. No more vibration with the Terra Firma spacers ?? Thinking of getting one too
Post #569578 9th Oct 2016 12:51am
SkyFallSilver
Kuwait
Thanks no vibrations now and its well built. 2016 Defender 90 Adventure Edition
Post #569795 9th Oct 2016 9:14pm
dgardel
Italy
The snow cover protect the cabin duct, not the engine duct..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #570029 11th Oct 2016 11:24am
JOW240725
I've also run the Terrafirma 30mm spacers for last 6 months without any issues. greatly improved turning circle!! James
Instagram @suffolk_rovers
Post #570034 11th Oct 2016 11:48am
SkyFallSilver
Kuwait
Recently crossed 85,000 KM and the Defender has been quiet reliable other than the weak links in the intercooler pipes or turbo manifold gasket which has been changed to Nakatanenga.
Changed the Rear Fogs and Revers to Perie 95mm NAS they look much nicer than the Wipac's
Have replaced the startech handbrake to the limited edition leather variant similar to my adventure edition in addition to fixing the the new front end badge similar to the Xtech series.
Its quiet tiring now since its Ramadan and fasting, will tackle the clutch and clutch slave cylinder for an amended one to make it lighter and remove the clutch rattle when idle its about time. 2016 Defender 90 Adventure Edition
Post #709278 26th May 2018 9:26am
