Home > Td5 > Anyone got a clue what this mess might be the remnants of?
bifterx
United Kingdom 2004 Defender 110 Td5 DCPU Oslo Blue
Thats a 30 amp fuse out of that relay thingy - I think it goes on down to the starter motor, you can sort of see it disappearing down.
The truck has had the EGR gubbins removed - I think normally EGR / ILT modulators are fixed to the wing this side. IS this likely the remnants? Theres quite a few loose wire ends kicking about.
Best just to stick connector blocks on the end s of the loose ones and cable tie it up tidily?
Handily, after taking this photo I dropped my phone down into the inner wing - which I though was going to be inaccessible. After a great deal of cursing and visions of removing the wing in the dark to get the thing out, I found out that by removing the 2.5kg of packed mud and dirt from the gap at the bottom and on from on top of the chassis member, my phone then fell out nicely into my hand. Note to self: Pay more attention to mud traps. Disco 300TDi XS - Gone
Disco 3 SE manual - Gone 😭
Freelander 2 SE manual
Defender 110 TD5 DC
Post #567175 27th Sep 2016 10:33pm
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
I have a similar set up which is an electrical supply for the valve block on my hydraulic winch.
It definitely looks like a secondary electrical supply of some sort. Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #567178 27th Sep 2016 10:43pm
Riccarton
Scotland 2012 Defender 90 Puma 2.2 HT Zambezi Silver
Spot lights perhaps?
Post #567179 27th Sep 2016 10:43pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Yup looks like a typical extra lights wiring set up to me... fuse, relay, wires to nowhere? Does it go a switch on the dash under the clocks? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #567183 27th Sep 2016 10:54pm
bifterx
Spots are a pretty good shout. When I bought it, I recall it had a disconnected work light on the side of the rack but no switches in the dash.
Seems like a bloody mess for a spot light or 2 though. Disco 300TDi XS - Gone
Defender 110 TD5 DC
Post #567185 27th Sep 2016 10:58pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
looks to me like spots too. The starter motor has been used as it is fed directly off the battery 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #567191 27th Sep 2016 11:24pm
