Home > Technical > Quick question on wiring electric windows.
Welkman
Hi all,
I have an aftermarket kit for my 110 which came with two reversing polarity rocker switches. I reckon i need to run a 2.5 mm feed to them via an ingnition switched relay and then direct to the motors. This does put the full load through the switches. I have lost the instructions and cannot find out much about the wiring except what terminal needs to go where. Does this sound normal or should I be trying to protect the switches with more relays?
james
Post #567014 27th Sep 2016 1:59pm
gilarion
Without knowing what kit you have it is hard to advise, however I can say that genuine electric window motors and switches do not require a relay, so maybe your kit does not. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #567039 27th Sep 2016 3:46pm
Welkman
Thanks. I think it is one of these kits http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...0785912717 the instructions got lost in my house move !
Post #567046 27th Sep 2016 4:05pm
gilarion
Looks a good kit does the loom supplied come with relays if so use them if the loom does not then I would say none are required.
Either way this is step by step guide to fitting electric windows to a Defender with lots of Photos will guide you every step of the way...
Just follow the instructions in the link and you will not have any difficulty in fitting
http://www.mobilecentre.co.uk/images/Data_...indows.pdf For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #567073 27th Sep 2016 5:27pm
Welkman
Ah that website looks brilliant for all things electrical! Thanks
Post #567095 27th Sep 2016 6:24pm
