Home > Maintenance & Modifications > Webasto/Eberspacher pickup from Fuel Sedimentor? |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1630 |
as far as memory serves me you can not draw off a shared working fuel line. the wolfs i have are plumbed into the filler neck and my td5 is plumbed into the fbh port on top td5 pump.
easiest way is to drop into the filler neck pipe on most landys or tank top on a tdi |
27th Sep 2016 11:22am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8091 |
i run a puma 2.4 with airtop and thermtop C, they need two feeds for fuel metering pumps to have sufficient flow should both run together.
i drop the tank and ran two feeds in through the top of the the pickup housing. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
27th Sep 2016 11:59am |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2664 |
I run an airtop, similar to James'. I also have an aux fuel tank in the wing and decided not to connect the balance pipe to the main tank. This means that the main tank remains intack and no holes drilled into it, but I also lose about 4L capacity of the aux tank.
Not a big deal in my mind. So I used the balance pipe connection to feed my airtop. So as soon as I now fill up at the fuel station, I fill the 4L airtop tank first if you get my drift 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
27th Sep 2016 1:20pm |
Bumpymike Member Since: 18 Nov 2015 Location: cheshire Posts: 71 |
I fitted an addition standard pipe up into under seat 90 diesel tank - but to get heater pump to suck we had to feed the nylon pipe down the pick up pipe. It would not draw up the metal pipe.
27th Sep 2016 5:01pm |
