Home > Td5 > Transmission Rating - Uprated Transmission [108AA];
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
So I did a search of my VIN and one of the build items and code that was listed for my 110 was this "Transmission Rating - Uprated Transmission [108AA];". Anyone know what this means?? Just curious.
Thanks 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #566748 26th Sep 2016 4:31pm
4RF RDS
Really??? No one? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #567182 27th Sep 2016 9:51pm
Pickles
Re: Transmission Rating - Uprated Transmission [108AA];
Thanks
Perhaps you could put up an image of the document/words?
Pickles.
Post #567187 27th Sep 2016 10:01pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
next to last post on page 5 of this thread doesn't directly answer your question but might be of interest while you wait for more info?
http://www.defender2.net/forum/topic43701-60.html
Post #567188 27th Sep 2016 10:02pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
This is directly from Ashcroft's site:
"The R380 was introduced in 1994 with the suffix J which was a significant improvement on the LT 77 it supercedes> Differences included a steel oil pump (as opposed to the LT 77 fibre one), an additional 2 support bearing, used on the layshaft and the mainshaft, wider gears, bigger diameter synchro rings, synchromesh on reverse and a longer mainshaft spline.
This suffix J did unfortunately have a couple of design flaws which gave the R380 some bad press, they were prone to the mainshaft shearing across the oil feed holes, the layshaft also sheared at a stress concentration behind the sandwich plate causing loss of 5th and reverse also early ones still suffered from mainshaft wear until the cross drilled transfer case gears became fitted as standard on the suffix G transfer cases.
In 1999 the suffix K was used very briefly for a few months then came the suffix L. The K and L are virtually identical, the only difference I have found is the L outer main casing has an additional strengthening rib, internals are the same. The J and K/L are very different, 2 of the bearings were substantially uprated and pinion and layshaft teeth were widened again, this results in a much stronger unit."
Possibly you have a suffix L ? Have you found the transmission serial number? it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #567190 27th Sep 2016 10:16pm
4RF RDS
That is it Thanks. It is an "L". Curiousity only... one of those "now you know" moments.
Cheers everyone. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #567317 28th Sep 2016 1:14pm
