Home > Technical > Puma 2.2 engine break
Penguin
Belgium 2015 Defender 110 Puma 2.2 HT Chawton White
I love our 2015 2.2 defender. It's great to drive, and great for climbing.
But descending is hell.
I'm not speaking about off-roading, it works there, but only in 1 low, sometimes in 2 low.
When on holiday in the mountains I had to break at every descent. In any gear, the engine's rpm goes over 4000rpm. This results in very hot rims when at the bottom of the mountain.
Is this something that can be "fixed" 28/02 - Loss of a good friend...
In a time of chimpanzees, I was a penguin.
Post #565968 23rd Sep 2016 5:55am
ericvv
Descending at normal mountain roads it must be possible to find a gear that keeps rpm down to 3000 or less without using the brakes?
I guess your truck with all the serious mods is quite heavy of course (my own 110 SVX with not much mods was defined as weighing more than 2.4MT by our tech inspection here recently), so you have a lot of weight to slow down.
Personally when I drive down from mountain altitudes here, the worst that I may have to do is select 2H to keep the engine at 3000 rpm, normal descents usually even 3H works for that. Sometimes I have to help with a short brake pedal push, but surely not continuously.
There is one big difference of course between the Puma 2.4 and your Puma 2.2. Engine compression of the 2.4 is 17.5:1 while that of the 2.2 is only 15.5:1. I have experienced it with a Puma 2.2 of a friend here (also a 110SW like mine), his engine braking is much less than mine.
I guess the only solution is to select even lower gears than you have been doing.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #565974 23rd Sep 2016 6:38am
Penguin
Even 1H can't hold it on mountain roads.
Only thing that worked was 2L, but then we descended at a very very low speed. Putting it in 3L and it went to the max RPM
True our def is no longer at original weight, but still not at maximum weight.
I do want/need to find a solution for this, as I'm afraid one day I'll be ending up having no breaks anymore. 28/02 - Loss of a good friend...
Post #565976 23rd Sep 2016 6:43am
ericvv
Replace the 2.2 by a 2.4... Whistle
Seriously, guess only thing you can do in such extreme descending situations is use 2L or even 1L when required. Too much speed at such steep tracks may quickly make you loose control if something unforeseeable happens.
Post #566011 23rd Sep 2016 10:56am
mk1collector
You could replace the brakes, bigger callipers and discs should brake better and cool quicker with the bigger surface area. Ray
My build thread
Post #566012 23rd Sep 2016 11:12am
Penguin
it's not even extreme descending. Just riding in the mountains.
How does a ford transit van with this engine cope with it?
Other brakes might be a solution, but then I'll first have a word with Land Rover. As if that is the only option, it's a design failure, with accidents waiting to happen. 28/02 - Loss of a good friend...
Post #566029 23rd Sep 2016 12:05pm
VeeTee
Netherlands
Weird... When driving my old 300Tdi in the Alps in most cases I can select 3H or 2H with an occasional short press on the brake to maintain a safe speed on descents. I think it should be the same in the Puma, otherwise I certainly would have Land Rover do some checks on this subject. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #566070 23rd Sep 2016 2:52pm
Penguin
It did that with our TD5 and D3 also, except this one.
I'll contact the dealer on Monday for this 28/02 - Loss of a good friend...
Post #566074 23rd Sep 2016 3:14pm
ericvv
As said, I had the experience in a Puma 2.2. Much less engine braking than in my Puma 2.4 in exactly the same circumstances. My theory is the lower engine compression plus 200 cc less displacement responsible for that.
Post #566098 23rd Sep 2016 5:37pm
VeeTee
Netherlands
According to Land Rover Specifications the compression ratio of the 300Tdi engine is 19.5:1. That is a reassuring thought next time I am driving in the Alp mountains... Thumbs Up Wink Cheers, Vincent
MySite
Post #566107 23rd Sep 2016 6:39pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
Ik would not be in your place with engine at 4000rpm !
I agree I have the feeling engine brake is less good as before, driving 110 and Defender from 1980.
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #566642 26th Sep 2016 3:38am
Caterham
do some trucks have a valve on the air intake to stall the engine?
could something similar be introduced?
Post #566683 26th Sep 2016 12:45pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
They have a flap in the exhaust to close it off
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #566851 26th Sep 2016 10:09pm
Caterham
thank you.
Am I right in thinking this was also used as a form of additional braking?
Post #566887 27th Sep 2016 7:39am
There are two systems in widespread use on HGVs. There is the exhaust brake (also widely but incorrectly known as an "exhauster"*) which in simple terms is a valve which blocks or restricts the exhaust cuasing the engine's back pressure to increase, and thus providing more engine braking. This is a relatively simple system but requires the exhaust to be suitable and is not terribly good for the engine.
A more sophisticated and reliable (but much more expensive) system, albeit a properly-engineered one is a device known as a Jacobs Brake or "Jake Brake" after the firm which pioneered the device. This uses an additionale camshaft (or clever camshaft trickery) on the engine to modify the valve events on over-run so that the engine's exhaust valves remain shut until fractionally before TDC is reached, thus turnign the engine into a compressor and providing very effective engine braking, far more so than is prossible with an exhaust brake.
The downside of the Jake Brake is that there is an almost explosive release of pressure when the exhaust valve opens, which makes them significantly noisy in operation. You can alsways tell when a Jake Brake is in use, usually from a considerable distance away. For this reason many countries have legislation prohibiting their use in residential areas.
There are many videos on YouTube which demonstrate clearly the sound of a Jake Brake in operation.
It is probably not economically viable to fit either an exhaust brake or a Jake Brake to a Defender, which is a shame since an exhaust brake woudl be ideal for the scenarion the OP is asking about.
(* For info, and "exhauster" is actually a vacuum pump used on some vehicles and more commonly railway locomotives with vacuum brakes for creating the vaccum required for the system to function and is nothing to do with engine braking systems).
Post #566921 27th Sep 2016 10:21am
