![]() | Home > Expedition & Overland > Help please sankey hitch bolts size? |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 ![]() ![]() ![]() |
Hi can anyone tell me the size bolts I will need to attach a sankey na to hitch to a slider plate ?
I used M12:
![]() Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Thanks for the replies I used m12 in the end
All the stuff I've attached to my slider plates I've used M16 bolts because that's the size of the hole.
Not sure I'd be happy with M10 or M12. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2693 ![]() ![]() |
Four M12 bolts is fine. Use 10.9 or 12.9 grade.
Most important is ensuring they won't just pull through. When I did it I had two pieces of 10mm and 8mm plate drilled to match and put them either side of the crossmember. |
^ The proof load for a (single) 8.8 Grade M12 bolt is 48900 N - approx. 4890 kgs - (and 10.9 Grade is 70000 N), so four bolts sure must be enough to pull the sankey? ... Cheers, Vincent
Sure, but why engineer when you can over-engineer?
![]() I was fitting it for different purposes: ![]() Click image to enlarge ![]() Click image to enlarge |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1768 ![]() ![]() ![]() |
Biggest that will fit through the holes. So M16 I believe. 8.8 at least.
