Home > Technical > what do you think, broken?....
jst
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #563975 14th Sep 2016 9:39pm
mk1collector
Just drive through some sticky mud, it'll be fine Whistle Ray
My build thread
Post #564000 14th Sep 2016 10:16pm
Yup, broken. Big Cry
Post #564003 14th Sep 2016 10:20pm
williamthedog
Duck tape and cable ties....sorted Wink
Post #564044 15th Sep 2016 6:30am
roel
How did you manage that? jumping and landing on some rocks? Roel
2003 90 Td5 (2009-now)
Post #564053 15th Sep 2016 7:25am
shaggydog
Good effort though thats had quite a thump! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #564137 15th Sep 2016 12:39pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Ouch!! Shocked Cogito ergo sum
Post #564140 15th Sep 2016 12:51pm
If I am right in thinking that that is the joint between the gearbox extension housing and the transfer box, a common cause of that damage is a hard frontal impact pushing the front axle backwards until the front propshaft extensible section is full compressed, whereupon it pushes the transfer box backwards. The fact that the force is applied to the transfer box alont the axis of the output shaft tends to twist the transfer box and break the offside gearbox extension housing before the nearside.
Done hard enough it is possible to get the transfer box to seperate completely from the gearbox.
I imagine however that if you have had a frontal impact of sufficient severity to do that you would have noticed the other damage!
Post #564168 15th Sep 2016 2:07pm
nickhodgson
Might need to consider bent gearbox mainshaft as well.....
Do you have standard front suspension and propshaft? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #564171 15th Sep 2016 2:17pm
jst
he be right. 1988 hardtop fell off a track.
No one in it, handbrake failed after unhitching trailer. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #564434 16th Sep 2016 10:59am
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
holy moly - not what you want! Shocked
Post #564435 16th Sep 2016 11:06am
jst
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #564437 16th Sep 2016 11:12am
