Home > Puma (Tdci) > Puma difficult to start
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
Hi All,
I have a 2008 110 2.4 Puma which is difficult to start. It turns over and over for a fair while before actually catching and starting - usually accompanied by a large cloud of smoke which is probably unburnt diesel. If it is stopped and started again soon after it usually starts easily.
It has been fine in the past but the vehicle has been tucked up in the shed for 4-5 weeks while I got round to changing the vacuum pump. There was only about a quarter of a tank in it so I filled it up a couple of days ago to make sure there was plenty of fresh diesel in it. Once it's going it runs ok although maybe a little rough for a while.
Seems strange the leaving it parked up has caused these problems.
Anyone have any ideas?
Dave
Post #561470 5th Sep 2016 2:56am
v8bobber
Just a quick bump for this thread as I nearly didn't make it to work this morning. It took three protracted cranking sessions to get the vehicle started.
There was plenty of smoke coming out of the exhaust while the engine was cranking but would not fire.
I have drained some fuel off the filter but it seems to be 100% diesel with no water in it, so doesn't look like water in the fuel. Seems strange though that this has happened after the vehicle had been sat (in my shed) for a few weeks.
I have a nanocom that I haven't had chance to plug in yet but will plug that in when I get home. Any ideas to consider while I wonder if I'm going to make it home or not?!
Dave
Post #563097 11th Sep 2016 8:58am
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
Could it be an air leak with air getting into the diesel line?
Never had this with my Puma but have with other Landrovers.
This might explain the need for cranking.
Post #563390 12th Sep 2016 5:06pm
Riccarton
Scotland 2012 Defender 90 Puma 2.2 HT Zambezi Silver
Have you read any codes? I'd be checking the heater / glow plugs and associated circuit.
The plugs continue to heat after the engine has started and without them they do run a tad lumpty for a while.
Post #563395 12th Sep 2016 5:12pm
agentmulder
Kuwait
Mine smokes a wee while but always starts, but ditto on above advice >> first target for checking are the glow plugs. Solved the bowel problem, working on the consonants...
Post #563521 12th Sep 2016 9:59pm
HardCharger
Weak battery?
Post #563536 13th Sep 2016 3:58am
hornet
Re: Puma difficult to start
v8bobber wrote:
Hi All,
Dave
I would bet the problem can be limited to (one of) the injectors or their gaskets. I do not think it has something to do with glow-plugs except your ambient temperatures are extremely low. In that case a faulty CHT-sensor would cause similar problems.
Post #563541 13th Sep 2016 5:00am
hornet
Dave
Problem solved? What turned out?
Post #574895 2nd Nov 2016 4:54am
