VCV replaxemetn
I am looking into a fault with my 2008 2.4 110 and it looks as if the VCV might well be at fault.
I know you need to do a pump learn after its changed but will the vehicle drive after its changed without calibration or does it have to be done at the time. What I am thinking is changing the VCV at home and driving it to the dealers (about 3 miles away) to have the pump learn done.
yes you can drive it....Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
11th Sep 2016 8:55am
Cold_n_Wet
You have to get the engine to a certain temperature to be able to do the pilot learn anyway so driving to the dealers should not be a problem."Rafiki" 2007 110 STW - Rolling rebuild.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
