Home > My Defender > Weekend Job: Lowering and Softening my Defender Suspension
Page 1 of 3 123>
MartinK
So - following this thread http://www.defender2.net/forum/topic47998.html
Bought some -2" , 20% softer tri-rate springs from here: http://www.coilsprings.co.uk/
I also purchased a Galvanised/Stainless Spring Seat kit from YRM: http://www.yrm-metal-solutions.co.uk/epage...oducts/225
Arrived today:
Nice little job for the weekend Thumbs Up
Write-up to follow Cool Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #562107 7th Sep 2016 10:18am
MartinK
Also wondering if I will need dislocation cones... Confused Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #562108 7th Sep 2016 10:20am
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
Why? If you've lowered it by 2" your not going to be doing anything serious off road!
Post #562130 7th Sep 2016 11:57am
MartinK
True - green laning is as far as I get.. that's about it... Articulation may be reduced (possibly), but it won't effect the off-road stuff I do...
Will probably do the next off-road event at Aviemore...Maybe even the off-road course at the LRO show...?
Just thinking that the springs will not be under load at the extent of the travel, and could dislocate??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #562134 7th Sep 2016 12:04pm
Pinky
I see what you're saying but I think other things may foul before you dislocate. However, if you have it all apart, for the sake of a few quid you might as well put some in!
Post #562180 7th Sep 2016 3:27pm
The bump stops should prevent dislocation combined with shocks & ARB if fitted.
I'd consider doing either F or R each day as the whole lot in one go is quite a job.
You might also want to consider Spring isolators whilst you at it, they'll give you a bit more lift back but soften and smooth everything.
On a 90 you can do top and bottom placement, or one sided or what yiu like.
Post #562189 7th Sep 2016 4:18pm
MartinK
OK - job done...and I am delighted Smile
So...first thing to say - I don't like the jacked-up-back-end look... also makes the back too hard (bouncy/jumpy) when lightly laden, and too high for my trailer:
^^ "Before" I changed the springs
So I put the spirit level on... when I hold the spirit level along the gutter you can see the slope:
or on the side steps:
Old spring (L) and new spring (R):
Thanks to Custom90Steve - I now have isolators
She now sits level:
I'm delighted. The ride is transformed. The 20% softer spring is amazing. Combined with the KONI shocks and Isolators (top & bottom) it's a terrific improvement.
Thanks Custom90Steve for the info on Isolators (£4.05 each "Isolator Rear Spring" Part # ANR3060 )
Thanks to LiftedDisco for the recommendation for the coilsprings company - great guys, great product Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #562972 10th Sep 2016 6:43pm
Morepower
New Zealand
Hi Martin, You may also notice that the steering will center a little easier now..
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #562996 10th Sep 2016 7:51pm
Stacey007
If anything that last picture it looks slightly lower at the back?
What will it be like if you put a heavy load on the back such as a caravan? would it drop more than std?
Is it generally a softer ride?
Other than the springs and mounts have you any other mods,
Thanks
Post #563002 10th Sep 2016 8:11pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
did you change all 4 springs.
can you let me have the spring rates, I might change mine as well. Be interesting to hear the cost as well.
Thanks
Post #563009 10th Sep 2016 8:35pm
Thumbs Up Thumbs Up
Post #563011 10th Sep 2016 8:38pm
MartinK
Thanks
Much softer ride. Just compliant now instead of just choppy and hopping and kicking over bumps. More like a Disco2.
Not sure the load would make a difference? I always thought the nose weight of the trailer was supposed to be fairly minimal (~75kg or so) anyway? As in the trailer should be fairly balanced?
The rear is now very slightly lower than the back... but very close to level - may do the fronts (below) now to match
Just the rears so far...after the success I may order a pair of fronts. Maybe 30mm lower, and add the isolators as well - thus making the front just 20mm lower...
As for the spring rates... the standard CSW springs are supposedly “triple rate” (269/315/406 lb/in) - I emailed coilsprings this spec, and asked for 20% softer and 5cm lower. Maybe Neil Satur (the chap I communicated with at coilsprings) has my order on file and can make more the same... I am guessing by the winding of the coils that they are variable rate, so should be fine when laden...
Costs? £130+VAT (£156) for the springs
£4 ea for the Isloators (I used 4 on the back... upper and lower
the YRM galv kit would be a personal choice unless yours are badly rusted I guess... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #563013 10th Sep 2016 8:56pm
bm52
Very interesting.
Once you have spent some time in them I would be interested to hear if you need an uprated rear ARB.
Thank you
I am watching las night of the proms and i compltely missed the last piece as i was reading your posts again. Always next year....
Post #563020 10th Sep 2016 9:15pm
MartinK
Quote:
Very interesting.
Thank you
Strangely enough...
Just bought a 2nd hand "Alive" one http://www.defender2.net/forum/topic49029.html
Not collected yet.
TBH handling right now seems great - I don't really notice any extra body roll... But with chunky AT tyres I don't really go round corners fast anyway Wink Whistle
Last night on a dry road I pitched-in to a tight corner at a good speed and the body roll was very similar to what it was before.
I'll go ahead with the Alive ARB, and try it when I get chance to fit it.,.but not expecting much difference
Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #563082 11th Sep 2016 7:58am
MartinK
BTW on the subject of dislocation cones - I didn't bother, and having fitted the new springs, I would be astounded if you did need a dislocation cone. The ARB seems to keep them planted... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #563084 11th Sep 2016 8:01am
Page 1 of 3 123>
