![]() | Home > Technical > BOING Noise !! |
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 ![]() ![]() ![]() |
Basically describes the noise I'm getting at crawling speeds from the bulkhead pedal box type area !
My mrs has told our 4 year old it's a mouse on a diving board ! Which he thinks is hilarious I on the other hand am not so joyous of the thought my TC or abs is ![]() Has any one else had this ? DEFENDER XS CSW 08 TONGA GREEN |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
I know the noise you mean but ive only herd it when i programed he car for the saudi speed limit warning.
I have not herd it a slow speeds i must admit. Call in to my garage if you wish and ill put it on IDs diagnositcs and take a peep for you. Regards Pete |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
not sure if we're talking about the same thing here but yesterday I had a bong sort of noise (mechanically gerated not like a diliberate electronic sounder) which I believe was a result of the traction control operating?
Scallops Member Since: 15 Aug 2007 Location: Brisbane Australia Posts: 89 ![]() ![]() |
I too had this boing noise - And I too thought it might be the ABS modulator, then I considered the front suspension springs may have reseated off centre - but then a week later I found, under the clutch pedal on my rubber floor mat, 2 grease covered grey plastic parts. I didn't know what they were - took them to the dealer.
They refitted these clips - they go under the springs on the clutch pedal. The boing noise has gone. |
Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245 ![]() ![]() ![]() |
I get the same boing sound when traction control comes on, it is very noticeable at slow speeds and can still be heard at high revs but is less obvious.
I would love to know what it is caused by as it sounds like a spring sound, to me. |
PHEW !!!!!!
Not that its any consolation to you guys but at least i'm not the only one ! ![]() |
