![]() | Home > Tdi > 200/30tdi inter compatibility |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 726 ![]() ![]() ![]() |
Hi guys, the 200 tdi defender engine in my 130 is tired, looking around my best bet for a Cost effective solution is a discovery engine from a donor disco. Now the 300 is far more plentiful, but will my defender turbo/ inlet/ exhaust gubbins fit on it to keep things kosher? I'm presuming on a 200 they definately are? I've had straight disco lumps in previous defenders and can't be doing with it all being 'not quite right'..
Many thanks in advance Cheers. Alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1823 ![]() ![]() ![]() |
I don't know about swapping bits 200 - 300 but I know the defender / disco manifolds are different, Defender being 'high turbo' the disco being low
I don't think many parts are interchangeable 200 - 300 |
Yes I want my defender high turbo on the disco lump, then I keep standard exhaust and am able to change a starter motor without dislocating my wrist...!
Alex
I wouldn't worry too much about the starter motor, once you remove the induction pipe from the turbo you have more than enough access to get to it, I have hands best described as shovels and I can change a starter easily. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
I cursed and swore last time mash, had to take exhaust off to get it out, plus I've got all the 'right' gear so would really like to go with that rather than a Steve Parker exhaust etc etc...
Cheers! Alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
Thanks fs that's what I wanted to hear, anyone know of a rotten 200 tdi disco going cheap?!?...
Cheers alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Might be worth giving CWS a bell
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 ![]() ![]() ![]() |
Ebay has a few £200-£700
